05-04-2017, 04:18 PM | #1 |
67 C10 Big block frame notches
I need to notch my 67 frame for a big block installation. I traced some patterns off a 68 frame.
Here are the cut lines transferred onto my frame. Before I start cutting I want to ask, do they look correct?
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
05-04-2017, 04:36 PM | #2 |
Re: 67 C10 Big block frame notches
That's quite a notch, have to take out that much?
Wow, never mind I just measured my frame 1-3/4'' wide flange at the top. Looks like a lot with the template there |
05-04-2017, 04:40 PM | #3 |
I guess they recently changed the frame on big block trucks?
Weren't they were all the same when manufactured.... I get it now. Its a 67, I never noticed the frame was different except for the steering box. |
05-04-2017, 05:01 PM | #4 |
I was thinking that it looked like a lot to cut. Is your's the same?
05-04-2017, 05:53 PM | #5 |
No, I don't have a 67 but I went and looked at both my trucks 68 GMC and a 69 GMC. Look the same as your template.
05-04-2017, 06:01 PM | #6 | |
Thanks for checking.
05-04-2017, 10:24 PM | #7 |
Kudos too you for making the cut too resemble factory rails.
That's a pretty good cut. I cut into the frame about 1/2" deep and I made mine about 3/8" longer than the frame stand for a little wiggle room forward and aft. I mocked mine up with the headers and was happy I had plenty of clearance for the headers so I decided not too cut it like the factory did. Be sure too clean up and smooth out those cuts too keep cracks at bay.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
05-05-2017, 12:37 AM | #8 | |
I'll chop it up it in the morning.
