Old 05-05-2017, 11:05 AM   #1
GasWorksGarage
81 bed swap question.
I am new to the forum. I have 2 81 pickups. ! fleet side 1 step side. I want to put the step side bed on the fleet side chassis. My question is are they interchangeable?
Thanks in advance.
GasWorksGarage is offline   Reply With Quote
Old 05-05-2017, 11:12 AM   #2
rip2174
Re: 81 bed swap question.
i didnt have any problems on my 84
rip2174 is offline   Reply With Quote
Old 05-05-2017, 12:30 PM   #3
Keith Seymore
Keith Seymore's Avatar
Thanks in advance.
Absolutely.
Assuming they are the same wheelbase (ie, both SWB or LWB); the only changes required might be the gravel shields over the rear bumper.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-05-2017, 12:58 PM   #4
GasWorksGarage
same wheelbase. what about the gas tank?
Old 05-05-2017, 01:18 PM   #5
Jstock85
81-87 should match without any problem as long as wheel base are same length and fuel tanks are on same side? Is that correct?
Jstock85 is offline   Reply With Quote
Old 05-05-2017, 02:45 PM   #6
rip2174
Yes the side tank will line up with the step side. Only problem is if you have dual tanks. you will have to make sure your pass fender has a gas cap door in it.
Old 05-05-2017, 03:55 PM   #7
GasWorksGarage
Is there a way to unplug the bed harness? if so where?
Old 05-06-2017, 06:41 AM   #8
homemade87
If I remember correctly the harness follows the frame rail to the back . No need to do anything there and just remove the tail lights and remove the socket and harness and drop it down on both sides and you done . You will see when you get in there .
homemade87 is offline   Reply With Quote
Old 05-08-2017, 09:34 AM   #9
GasWorksGarage
The harness does unplug in the bumper. The bolt holes for the bolts holding the bed will line up??
