Old 05-06-2017, 03:59 PM   #1
David Maddux
Radiator cap for v-6
Does the v-6 need a different radiator cap from the v-8's? Min wants to puke out quite a bit of antifreeze. It appears the neck on the radiator is long enough that my cap has no spring compression when tightened down. Just wondered if anyone has been through this?
David Maddux is offline   Reply With Quote
Old 05-07-2017, 12:10 AM   #2
Bob B.
Re: Radiator cap for v-6
No, my '67 351 V-6 uses the same radiator as a '68 396 with AC. Same 13 lbs. radiator ca p most any '67 uses. Do you have some kind of custom radiator?
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 05-07-2017, 08:15 AM   #3
David Maddux
This radiator is the original, just cap has been changed. If you top it off it will throw it out the overflow tube. Doesn't get hot although. I will do some measuring with with my micrometer and see how deep it is verses the distance it takes to compress the cap spring.
Old 05-07-2017, 09:30 AM   #4
geezer#99
geezer#99's Avatar
Do you have an overflow tank or coolant recovery system?
If not then don't keep filling the rad up. Let the level stabilize where it doesn't puke any coolant out.
geezer#99 is online now   Reply With Quote
Old 05-07-2017, 07:33 PM   #5
David Maddux
no overflow tank or recovery system on this truck. Just stripped down model.
Old 05-07-2017, 07:38 PM   #6
terry b
terry b's Avatar
Does the coolent end up about two inches down in the tank after it pukes and cools down? If it does that's where it wants to be.
terry b is offline   Reply With Quote
Old 05-07-2017, 07:42 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Why not add a recovery tank? Cheap & easy, and there's the benefit of an always-full radiator. You'll need a closed-system radiator cap, also inexpensive.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 05-07-2017, 10:33 PM   #8
David Maddux
Thanks Mike, like I said, it never seems to get hot and yes about 2 inches down. I may do the recovery system. Been driving this old truck for almost 50 years. Grandpa bought it new, I was 13 or 14 when it first came home.
Old 05-07-2017, 11:41 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
That brought a smile to my face. I bought my '72 in 1977, so I've been driving it for 40 years now. Showing its age but it still gets the job done.
- Mike -
RIP El Jay
Old 05-08-2017, 12:54 AM   #10
Bob B.
No overflow tank on mine, coolant level about 1.5" down from the top. Sounds like you don't have a problem!
