![]() Join Date: Nov 2015
Pushing rear wheels out?
I am currently running stock steelies with 235/75/15 tires. I like the look but would like to get the rear wheels farther out. I don't foresee buying different wheels in the near future. Can I use wheel spacers? If so, what thickness would I need to "clear" the stock lugs? I just cruise in my '64, no hotrodding with the 250.
Re: Pushing rear wheels out?
I bought wheel spacers for an American Racing set of rims and tires I put on mine years ago. I have since gone back to the original steelies and left the spacers on with a 3" coil drop and it rides great. I cant remember how thick they were but a lil over an inch is what I recall. Either 1 1/8" or 1 1/4". I will have to pull tire to confirm. As I recall, finding the spacer was relatively easy.
Excellent! Don't worry about measuring. I'll look for the 1-1/4" spacers just to be safe. There was a 1-1/2" set on craigslist. Would that be too much? Don't want the tires rubbing on fender. (Guess I could just go measure how much room there is. Duh!)
Might have to change wheel studs with that thick of a spacer. I'm using the late 70's Blazer 15 x 8" stock wheel with a 235/75R15 and they sit good.
With the spacers on mine, I still have about an inch clearance from the inside fender with stock 6 lug 1/2T rims.
these are what you need. Not just a flat spacer.
1961 chevy K10 my build is------------61K10 build |
The last of the six lug differentials were 1 1/2" wider. 1971 I believe. Helps a bit.
Never Ending Projects
Nope, very late '70 only were 6 lug but wider. '71-'72 were 5 lug.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
I'll have to look on craigslist and junkyards for a wider rearend. May be better in the long run.
When I switched to disk brakes I used 1" spacers to keep my original steel wheels and clear the calipers. I also used 1"spacers on the rear so the truck would track the same and look the same from the rear. I like the look a lot. Can post pictures tomorrow if you want. I also dropped the back 3 " and the front 2".
That would be great. With 1" spacers did you have the stock studs have to be shortened?
#13 |
These are the spacers I used. There may be better ones out there but I have had no issues with mine. I did not have to do anything with the studs.
https://www.titanwheelaccessories.co...FQ6LaQod9CABBw |
#14 |
I just bolted on a set like 61K10 shared. I used my lathe to turn a little out of the center opening to clear the concentric hubs. Worked like a charm.
