Brake Pedal Assembly
Is there any difference in a manual and power brake assembly? If so what is it? I switched my truck to power brakes and got the booster bracket from a forum member but the connecting rod is about an inch from the peadal. I can get it connected but it puts my pedal to close to the floor.
![]() Join Date: Feb 2013
Re: Brake Pedal Assembly
I don't think there is a difference, the push rod should be adjustable so that you can adjust the pedal location. the power brake pedal sits closer to the firewall because the bore in the master is larger and requires less travel to move the same amount of fluid.
double check the service manual for the proper pedal location I think it says how many inches off the firewall it should be.... I'm sure someone else will chime in as well. |
Normally there is a difference in pedal ratio between manual and power brakes.
The '69 and '70 charts that I have do not have that level of detail, but the 71 and 72 charts show around 6:1 for manual and 3.5:1 for power systems. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#4 | |
Posted via Mobile Device |
#5 | |
The Older Generation
1/2" - 1" from the bump stop. Here is an OLD thread that discusses the problem. http://67-72chevytrucks.com/vboard/s...d.php?t=151551 LockDoc
![]() Join Date: Jun 2005
I used the stock manual brake/clutch pedal assembly and just added a booster and the correct push rod. I even used the stock manual drum/drum master cylinder, and have not had any issues. Then I removed the clutch pedal from the assembly when I switched to an automatic.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
What he means is the power brake rod connects up higher on the brake pedal than the manual rod. If you are trying to use the same hole on the pedal, that's wrong.
The pedal assembly was for an automatic set up also. It just didnt have power brakes originally.
#10 | |
![]() Join Date: Apr 2005
http://www.mpbrakes.com/techtalk/how...ng-pedal-ratio
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
