Old 05-08-2017, 03:11 PM   #1
jbgroby
jbgroby's Avatar
60-66 Radiator Over flow tank
Hey Gang,
I’ve been speaking with another member (Pete Chronis) on what was the factory correct radiator overflow container for our 60-66 trucks. I have ordered a generic 2”x16” container to catch my water expansion when needed for now.
According to what we can see or find, most trucks (65-66) came with a larger radiator overflow tank. Classic Parts #78-416 and is reported to fit ’41-54’. This mounted on the right inner fender next to the battery. However, it’s the same design as what was used on a 65-66.
Does anyone in the group have better information?
jbgroby is offline   Reply With Quote
Old 05-08-2017, 05:37 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 60-66 Radiator Over flow tank
I don't think I have ever seen a truck of this era with a factory overflow tank. Most everything has been just vented. Even my '72 El Camino doesn't have one.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-08-2017, 06:20 PM   #3
Classic v6 GMC's
Classic v6 GMC's's Avatar
Well I had to change my response because I found the picture posted below.
Still I have not seen a chevy with one even on our factory a/c trucks.
Maybe they were a dealer installed item.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 05-08-2017, 07:05 PM   #4
Classic v6 GMC's
I started thinking about it and had saved this picture some years back of this 66 GMC Suburban with Factory Air Conditioning. Not sure if the tank is factory or an accessory.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 05-08-2017, 08:59 PM   #5
64shortbox
64shortbox's Avatar
I'm not sure if you are looking for a factory overflow tank (I've never seen one) or one that looks factory and fits our trucks. - If you are looking for an overflow tank looks good & fits our trucks you might look at the ones for the Ford Trucks. They are a Radiator Over Flow/Windshield washer combo and the cut of the tank fits the angle of our inner fenders almost perfectly and as a plus you can now add windshield squirters at a later date if you want. This is the set up I went with on my 64 C-10. I moved the horn relay and voltage regulator to the other side of radiator support using the original mounting holes and grommets for both. I later though did go to a one wire 120 amp alternator. I got mine from the wrecking yard BUT you can get it brand new from Rock Auto for $28.00 if you prefer to go that route.
Rock Auto Overflow
http://www.rockauto.com/en/catalog/f...ery+tank,10457
64shortbox is offline   Reply With Quote
Old 05-08-2017, 10:51 PM   #6
damnyankee36
damnyankee36's Avatar
damnyankee36 is offline   Reply With Quote
Old 05-08-2017, 11:13 PM   #7
damnyankee36
Uh, you're using a what? ;-)
Old 05-08-2017, 11:20 PM   #8
damnyankee36
Old 05-09-2017, 12:25 AM   #9
64shortbox
64shortbox's Avatar
Yep, I know a Ford Overflow/Windshield tank & pump combined with Ford truck windshield squirt nozzles, Ford Bronco wiring conduits for my power window & power door lock wiring, a Lincoln mark VIII electric cooling fan with a Volvo fan relay, Jeep Cherokee door check stops, Jeep Cherokee footwell lights, Chevy Van tilt column, 1964 Chrysler A/C vents and soon to be a 71 Cadillac emergency brake assembly that will automatically release when I drop my C-10 into Drive or Reverse. I don't shop at Jegs, Summit, Speedway etc., etc., I do my shopping during 1/2 off days at Pick N Pull. Besides my 64 C-10 I also own a 62 Pontiac Catalina, Tri-Power, 4SPD & 8 lugs, a 1971 M&M Hearse, a PT Cruiser 284,000 miles (my daily driver) & yes even a 06 F-250 for hauling stuff.
Old 05-09-2017, 11:18 AM   #10
60-66
60-66's Avatar
Chevrolet did not offer an overflow tank for 60-66 and I cannot find any supporting info for GMC. The one you show Jake is a reproduction of the factory one for Chevrolet of the 40s and 50s. The one in post 4, I dont believe to be factory judging by the mounting bracket. Pretty sure thats Steves Suburban.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 05-09-2017, 01:03 PM   #11
Brad54
Brad54's Avatar
Not to hijack the thread, but how do you activate the washer pump?
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 05-09-2017, 06:46 PM   #12
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
-Brad
If you are talking about the windshield washer, it's a button in the center of the windshield wiper switch.
66 C20 Service Truck:
Old 05-09-2017, 08:20 PM   #13
64shortbox
64shortbox's Avatar
-Brad
Brad,
As LostMy65 stated there is a pushbutton in the center of the windshield wiper knob on trucks that came with windshield squirters from the factory. I did buy the correct switch off eBay. The washer pump is built into the Ford Overflow/Windshield washer tank. The pump also is still available from Rock Auto new. I ran an ignition on fused hot to the pump. The push button squirter button completes the ground activating the washer pump.
Old 05-11-2017, 11:24 AM   #14
60-66
60-66's Avatar
.delete
Old 05-11-2017, 03:16 PM   #15
f66
f66's Avatar
My 66 has what looks like an add on of unknown vintage.
f66 is offline   Reply With Quote
Old 05-12-2017, 11:14 AM   #16
oldusafmsgt
oldusafmsgt's Avatar
I have the dealer truck data books for 60-66, a radiator overflow is not listed for any year as a factory option or an accessory.
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
Old 05-12-2017, 01:57 PM   #17
60-66
60-66's Avatar
Do you have any of the GMC Data books ?
Old 05-12-2017, 02:22 PM   #18
oldusafmsgt
No, sorry, I don't. The Chevy data books are hard to find, and can be expensive, and the GMC books even more so. The last GMC book I saw, a 1963, sold for $300.00, and that was 4 years ago.
Old 05-12-2017, 02:40 PM   #19
60-66
60-66's Avatar
Oh I know , I have every data book 1955-1970 but only 4 GMC data books. Priceless information that took a long time to find. But to confirm what you stated , the GMC and Chevrolet parts books do not list a radiator overflow can .
Old 05-12-2017, 02:47 PM   #20
oldusafmsgt
I have no idea what the GMC books say about a radiator overflow. In my 60-66 Chevy data books, I can't find a reference to one, either as a factory option or dealer installed accessory. I'm sure, like rear bumpers those years, dealers probably offered some aftermarket catch can if someone wanted one.
Old 05-14-2017, 09:57 PM   #21
reed62
reed62's Avatar
Originally Posted by jbgroby View Post
Hey Gang,
I went with an early 1990's Toyota overflow tank. Nice and narrow and mounted it on the driver's side radiator support.
reed62 is offline   Reply With Quote
Old 05-14-2017, 10:38 PM   #22
'63GENIII
'63GENIII's Avatar
Rock Auto Overflow
Got the same set up thanks to you 64 Shortbox. Cleanest set up, especially for the price that Ive seen yet.
Why not? There's a ton of guy rockin Honda door seals that work better than anything else thats available to us. Heck, the AC in my '63 is out of a '62 Chrysler
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 05-14-2017, 11:41 PM   #23
CRUZN66
CRUZN66's Avatar
Hey Gang,
Here's how I mounted mine.
CRUZN66 is offline   Reply With Quote
Old 05-15-2017, 12:30 PM   #24
LostMy65
LostMy65's Avatar
http://67-72chevytrucks.com/vboard/s...light=Overflow
Old 05-15-2017, 01:01 PM   #25
The Rocknrod
Moderator
The Rocknrod's Avatar
Interesting, I wonder if it works properly (return suction). I like the idea.
http://67-72chevytrucks.com/vboard/s...77&postcount=6
