Old 05-08-2017, 04:14 PM   #1
Capo_Customs
65 c10 Panckaed Crossmember question
So im about to pancake my crossmember 1.5 inches and ive read that you want to move the whole crossmember forward an inch to center the wheels in the wheel wells. But asi was looking at mine, it appears that if i move it forward, it will hit the steering linkage. Am i missing something?
Capo_Customs is offline   Reply With Quote
Old 05-08-2017, 05:48 PM   #2
SCOTI
SCOTI's Avatar
Re: 65 c10 Panckaed Crossmember question
You don't need to move it forward when pancaking the x-member. If you do move it, everything that connects to the steering needs to be moved as well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-08-2017, 06:17 PM   #3
Capo_Customs
I must have misread it then. So you just pancake and rebolt it in its original spot?
Old 05-08-2017, 09:08 PM   #4
bbbc10
Diggin The SquareLife
Yes
bbbc10 is offline   Reply With Quote
Old 05-08-2017, 10:14 PM   #5
Capo_Customs
Thank you
Old 05-11-2017, 09:23 AM   #6
timmytimm3
Porterbuilt makes "forward arms" to center the wheels and change the geometry.
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 05-12-2017, 01:53 AM   #7
andrewmp6
Yeah using forward control arms will be a lot easier then moving the crossmember.
andrewmp6 is offline   Reply With Quote
