Old 10-21-2003, 10:08 AM   #1
Slammed67
Progress = 0%
Slammed67's Avatar
Question Stock suspension height?
This was discussed a while ago, but I can't seem to find the information. On a stock height 2WD short bed 1/2 ton truck, what is the distance between the center of the wheel to the top of the fender opening? I thought it was 19" in the front and 22" in the rear. Can somebody verfiy this for me?
Thanks,
Jason
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 10-21-2003, 10:54 AM   #2
dubie
dubie's Avatar
I just measured mine and it was 22" in the front and 20" in the rear. But that's on a box under load and a front end with a 6 banger in it
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 10-21-2003, 11:17 AM   #3
zyggy72
Can't kick the addiction!
The only thing I have ever seen about stock suspension heights is measured from the ground to the top center of the wheel opening in the fender (slammed67 - your top 2 red lines) If I remember correctly, the heights were 32" in the front and 34" in the rear.
zyggy72 is offline   Reply With Quote
Old 10-21-2003, 12:31 PM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here's info from the 1969 resto pack.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-21-2003, 12:32 PM   #5
Slammed67
Progress = 0%
Slammed67's Avatar
I guess I should be more specific. I'm trying to figure out how much my truck is lowered from stock height. Measuring from the ground to the top of the fender doesn't do much good since there are too many variables involved like wheel size, tire size, air pressure in tires, etc. Measuring from the center of the wheel is the most accurate way to do it since the dimension will be the same regardless of tire size, etc.
Therefore, I would also need the measurement to be from a truck with an empty bed
Old 10-21-2003, 01:59 PM   #6
Suicide-D
Location: Katy, TX...but the love of my life resides in Dublin,OH.
http://67-72chevytrucks.com/vboard/s...threadid=21128
Suicide-D is offline   Reply With Quote
Old 10-21-2003, 02:00 PM   #7
Suicide-D
19" all the way around from the center of the wheel to the lip
Old 10-21-2003, 05:27 PM   #8
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Mi '69 was also 19" from the ground, here's another thread.
http://67-72chevytrucks.com/vboard/s...threadid=19367
chevy_fatman is offline   Reply With Quote
Old 10-21-2003, 10:54 PM   #9
Hugger
Hugger's Avatar
I just dropped mine with a 3.5" front, and 5" rear.
Front is 14.75"
Rear is 17"
So that fits with the 22" rear stock height, but the front at 19" stock would make mine a 4.25 front drop...
Stan or someone at ECE told me this front dimension at one time, when I was trying to decide what drop to go with.
72 LWB - Hugger Orange
350/350 3.73
Next; 335hp GM Crate
Hugger is offline   Reply With Quote
Old 10-21-2003, 11:04 PM   #10
Suicide-D
I'll measure my 70 in the morning it's stock...
Old 10-22-2003, 09:19 AM   #11
Suicide-D
I got 19.5" all the way around on the 70. from the center of the wheel to the lip. All of the trucks I have measured have been coil spring trucks, I don't know if the leaf spring trucks are different.
Where is this 22" measurement on the rear coming from?
Old 10-22-2003, 10:15 AM   #12
Slammed67
Progress = 0%
Slammed67's Avatar
It can't be 19.5" front and rear on a stock truck. These trucks were higher in the rear. Are your rear springs sagging?
Here is a pic of a stock height truck from Early Classic's site......
Old 10-22-2003, 10:34 AM   #13
Suicide-D
They must be sagging.(unless someone has done something before I owned it) What do you think... I don't think it has as much rake as the above picture...
Old 10-22-2003, 11:07 AM   #14
Hugger
Hugger's Avatar
ECE told me that the rear springs, compressed (installed in the truck) should be 12.5" to 13". Mine were 10.5" before the swap, so they were already sagging about 2"+ before the swap.
I have not measured the springs after the swap, will do tonight.
Also my stock daily driver does not have the rake that even Dirt Dobbers has, let alone the pictures on the ECE website. I will measure it tonight as well. I would guess it to be the same dimensions front to rear, as it does not have any rake to speak of...years of overloading a 1/2 ton (not by me of course!! )
350/350 3.73
Old 10-22-2003, 11:13 AM   #15
Hugger
Hugger's Avatar
Just saw this thread that was dug up from 2002.
FYI-
350/350 3.73
Old 10-22-2003, 11:14 AM   #16
mcmlxix
Collector of Projects
mcmlxix's Avatar
I measured the distance between the fender lip and the current tires I have on the truck. I wanted to figure out what drop I wanted. Well they are both the same front and back.( I think it was 5 inches for both. I can only assume that the springs are sagging. My worry is that when I dopt it, I wont have the amount I was looking for because of the old springs. I think I will just lower the front first and then match the back later....
Rich
1972 K5 Blazer CST Click HERE
Old 10-22-2003, 11:19 AM   #17
Slammed67
Progress = 0%
Slammed67's Avatar
Well, I guess I could unbolt my rear bags and jack up the rear of my truck until the distance between the trailing arm and frame is 12.5", then I'd know my answer.
Old 10-22-2003, 03:25 PM   #18
Hugger
Hugger's Avatar
mcmlxix - You need to measure down to the center of the wheel...not the top of the tire.
You should get a better result this way.
350/350 3.73
Old 10-22-2003, 08:57 PM   #19
dinnut
dinnut's Avatar
ahh.. the stock height rake. i wish it would die bagged trucks rock dont get me wrong.i like rakes just not when they are this frickin high
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 10-22-2003, 09:56 PM   #20
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
slammed
i got 19.5 in the front and 20 in the rear
70 chevy short fleet, with 350 and 700r4, 15x7 wheels with 235/75/15
i am sure that the rear is sagging on mine...
it looks level not at all like the pics from early classics
tommie
tommie is offline   Reply With Quote
