05-08-2017, 08:28 PM | #1 |
cut springs,replace or spindles
going to drop my 69 panel 4/5. On front end I have been told 2 coils should give 4" but that's limit. Question is am I better off cuting old springs,buying new lower spring,buying drop spindle or combonation.
Looking to improve handling and ride quality. Realize having both means giving up a little at each end.
Only the stupid know too much to learn something new. |
05-08-2017, 08:45 PM | #2 |
Post Whore
Re: cut springs,replace or spindles
I'd probably do drop spindles or coils and spindles..cutting that much off a coil will, have you almost bottomed out just sitting still..on my 85 I cut one full coil and dropped it about 2in..but its bottomed out on a big bump before
05-08-2017, 09:19 PM | #3 |
Drop springs go with spindles then springs if you go lower
70 SWB STEPSIDE 70 BLAZER 09 challenger |
05-09-2017, 07:58 AM | #4 |
Drop spindles keep the geometry the same (or real close) and you don't loose any suspension travel. So that would be my first choice. Then if you need more drop I would look at the springs, keeping in mind to much and you are going to deal with bottoming.
