Looks like I am missing a piece under the steering column as there are 2 empty bolt holes? What is it called? TIA
![]() Join Date: Jun 2005
Re: What piece am I missing?
It is a support and also acts as the brake pedal stop. I don't know the actual name of the part
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
laying low
![]() Join Date: Mar 2001
2 bolts. I don't think there is a plate to cover that. Pic courtesy of LMC.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
![]() Join Date: Feb 2009
What's lower steering column bracket for $100 Alex?..........Really, if I recall, that's a label I pulled from my cranium. If I remember right, I couldn't find a label or even a decent image in the assembly manual.
Ah, I knew I'd seen a pic. on this site. Courtesy LockDoc: http://67-72chevytrucks.com/vboard/s...d.php?t=643180 Lower Steering Column Bracket The lower steering column bracket is somewhat square. This attaches below the column to column support bracket clamp using four 1/2" head tapered screws with integrated washers. The screw threads are 5/16-18 x 13/16. There are two fixed nuts on the column support bracket and two on the dash panel.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-08-2017 at 10:17 PM. |
#5 | |
The Older Generation
You are missing the pedal stop bracket. It is held up by four 5/16" bolts. LockDoc
laying low
Ah, that's the one Leon. Pedal stop bracket. I had to go look at mine.
Never put it together that was a pedal stop bracket. Doc strikes again. Guess I need to edit my &^O^^^notes.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Ahhh "pedal stop bracket" thanks!
There should be one or two rubber bumpers in the square holes. (you can't see the holes in my picture). One bumper for automatics and two for manual transmissions.... LockDoc
Who Changed This?
![]() Join Date: Jan 2013
Got to love the knowledge here! If I go deeper into my truck, I'm going to have my wife photo the living snot out of the parts I'm working on (interior-wise- the engine, trans and suspension, I have figured out). My wife will take the pics, because I don't care what it is, my pics are always bad. I can take a pencil and paper and make a drawing that you would have no problem understanding, but a photo? I'm dead.
