Old 05-09-2017, 03:18 PM   #1
72timemachine
Will not start in neutral at times either??
Just to bring you up to speed, I had to replace the ignition cylinder lock due to the fact that the thumb tab ring snapped off and it felt like the key was going to break off each time I went to start the truck. I have about 2000 miles on this new cylinder so I do not feel this is the problem.
I have an 84 c3500, 6.2, th400, with around over 300,000 miles on it...runs like a clock. However, recently when attempting to start it the past several times it would not crank while in park....so I dropped it into neutral and it started right up. At other times it will not start up in neutral unless I shift it back to park then into neutral. Do you feel it is time for a new neutral safety switch or it may just need an adjustment? My starter is new and spins up great so no drag on the system there.
Thanks for any help.
72timemachine is offline   Reply With Quote
Old 05-09-2017, 04:05 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Will not start in neutral at times either??
I would check to see if there is play in the column switch on the base of the column.. if so change it
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-10-2017, 08:42 AM   #3
Jstock85
I 2nd Rusty. Def sounds like an electrical issue from the column. Hopefully tightening a couple screws or replacing a switch will take care of that for you!
Jstock85 is offline   Reply With Quote
Old 05-10-2017, 01:57 PM   #4
GM72K10
Next!
GM72K10's Avatar
Time for a new neutral safety switch
Inexpensive and easy to change
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
