05-09-2017, 05:45 PM | #1 |
Original Rocker and cab corner
Hi guys I am putting on a new rocker panel and cab corner and wonder if anyone knows or have an original truck and could look if the original cab corner is flat and has no lip where it meets the rocker panel I have an original cab corner in good condition and it does not have a lip where it meets the rocker panel just wondering if that is normal. Also does anyone know if the front of the rocker is even with the door or does it extent forward of the edge of the door ?
Thanks John |
05-17-2017, 04:04 PM | #2 |
Re: Original Rocker and cab corner
Trying this again still looking for an answer
Thanks |
05-17-2017, 05:23 PM | #3 |
Is this the view you need
Ed |
05-17-2017, 05:40 PM | #4 |
Hi Ed in the picture the arrow points to the cab corner area where it meets the rocker. There is no flange or 90 degree bend in that area I am wondering if that's the way it was from the factory. When you get an aftermarket cab corner there is a 90 degree bend there. I have a clean (I think) original cab corner I want to use but not sure if it is missing or was never there.
Thanks John |
05-17-2017, 08:49 PM | #5 |
Is that the bottom where the arrow is?
05-17-2017, 09:17 PM | #6 |
Yes
05-17-2017, 09:30 PM | #7 |
Arrow is pointing to the area on your picture where I am talking about, you should be able to see it from inside.
05-17-2017, 10:46 PM | #8 |
Here is the drivers side and passenger side, they both have a v shaped weep hole.
05-17-2017, 11:22 PM | #9 |
Thanks for the pictures
