Gas cap issue - now I have a fuel leak
I replaced my gas cap last week, the rubber was starting to tear apart and would no longer tighten. I went to Napa and got a replacement gas cap, different style, but the guy at the counter who has helped me in the past said the outside diameter was not important, as long as the inside diameter was correct (1 1/2 inches). Well, just today I noticed a small gas leak coming from the rubber hose that is connected to the fuel sending unit. It never leaked a drop in the 3 years I have had the truck. I tightened up the hose clamp a bit, slowed the leak, but not completely. I unscrewed the gas cap and it released a bunch of air pressure. Since then, the leak has stopped, but I have checked it a couple more times and more air pressure. I have a feeling the gas cap is not venting, since it is smaller outside diameter and not completely covering the filler neck flange, like the old cap, which is 3 3/4 inches. Could this be the problem with the new fuel leak??
1967 Chevy C10 Stepside SWB - 350/700r4 |
Re: Gas cap issue - now I have a fuel leak
You need a vented cap
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Should the vented cap completely cover the outside of the round filler neck flange like the old cap??
![]() Join Date: Nov 2007
The vented caps I've had in the past would hold so much pressure the tank would start bulging, so I don't know what PSI it has to hit before any venting happens. Due to current environmental rules I would guess "never".
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
I think the gas cap I have now is vented, but either I have it too tight, squeezing the rubber seal so it can't vent or because it doesn't cover the flange completely where the holes are in the photo, it has nowhere to vent, causing the pressure build up and the leak. Here is another picture of the gas cap underside.
