Old 05-09-2017, 08:26 PM   #1
1978chev
A/c parts
Ok guys getting ready to order some a/c parts, I called vintage air and told them
That I have an 02 5.3 ls motor in my c10 and I just wanted the evap kit since I will be using the factory a/c compressor that came with the motor. After them telling me it won't work I explained to them that it has been done before and it will work. Here is the parts list they gave me, I'm just wondering if this is it or will I need more parts or less parts.
Part# 751170 evaporater kit
# 521171 hose kit
# 021567 condenser and drier kit
# 11086- vus binary switch
Thanks for any help
1978chev is offline   Reply With Quote
Old 05-09-2017, 08:27 PM   #2
1978chev
Re: A/c parts
Oh yeah it's going in a 69 c10 (my sig says 78 it that truck is gone)
Old 05-10-2017, 07:47 AM   #3
Rich84
Rich84's Avatar
Re: A/c parts
Did your truck have factory air?
Rich84 is offline   Reply With Quote
Old 05-10-2017, 09:12 AM   #4
Jstock85
Re: A/c parts
Id like to know how that turns out. Ive always been under the impression that VA did its own thing independently of OE stuff. I could be wrong.
Jstock85 is offline   Reply With Quote
Old 05-10-2017, 09:44 AM   #5
solidaxel
solidaxel's Avatar
Re: A/c parts
What compressor are you using?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-10-2017, 07:14 PM   #6
1978chev
Re: A/c parts
The truck does not have factory air. And I am using the stock a/c compressor that came with the motor (02 Chevy Tahoe with the 5.3 non flex fuel)
Old 05-11-2017, 08:04 AM   #7
Rich84
Rich84's Avatar
Re: A/c parts
I will be looking to do the same thing as soon as I get my 84 up and running.
So what you are trying to buy is everything except the compressor?
Are you getting the vents etc from them?
Old 05-12-2017, 02:10 PM   #8
1978chev
Re: A/c parts
Yes this is everything they told me I will need it comes with vents and all for a non air cab
Old 05-12-2017, 02:15 PM   #9
Rich84
Rich84's Avatar
Re: A/c parts
Is it much cheaper without the compressor??
Old 05-12-2017, 08:46 PM   #10
Hart_Rod
Hart_Rod's Avatar
Re: A/c parts
You'll find a better price on the setup at Summit or Jegs.
Hart_Rod is offline   Reply With Quote
Old 05-14-2017, 06:37 PM   #11
compsystems
Re: A/c parts
I logged in here just to let you know it does work.
Vintage air under dash kit for non AC cab.
Vintage air Condenser kit with filter\dryer.
Trinary switch to trigger electric fans when AC pressure gets high.
07 LS truck compressor with side fittings, dual bolt.
Custom AC hoses.
Blows Cold down to 42 degrees at the vent.
KEY things to note:
Truck compressors are fixed displacement and work fine, LS cars used variable displacement and wont work well.
Charge the system to Vintage air spec, not what modern typical specs say.
The pressures should read what vintage air states in the manual.
compsystems is offline   Reply With Quote
Old 05-16-2017, 06:03 AM   #12
1978chev
Re: A/c parts
Thanks compsystem I knew plenty of people had done it just wanted to know if their was anything I'm missing
Old 05-16-2017, 09:58 AM   #13
solidaxel
solidaxel's Avatar
Re: A/c parts
How can you tell if it is a variable displacement compressor, I have three laying around from L S swqps
LS 3 4L70E
Old 05-18-2017, 01:28 AM   #14
compsystems
Re: A/c parts
google the part number and see.
