05-09-2017, 08:42 PM | #1 |
Radiator Shroud Help Needed
My truck has a 350 sbc in the I6 location, which pushes the motor and fan away from the shroud and radiator. Ideally, I need the shroud either to be ~2" longer, or the fan ~2" closer.
Can anyone with a 4x4 shroud measure the distance from the front of the shroud (radiator) to the opening of the shroud where the fan sits? Mine shroud from the radiator to the fan opening is 4 1/4" long. Is the 4x4 shroud longer? Is it safe to use a 2" spacer WITH a fan clutch? I read in a couple places on the interwebs that using a spacer would put more stress on the water pump bearings, which can cause premature failure. If this is do-able for a daily driver truck and safe, it would be the cheapest/easiest option (which makes me think not a very good one.) Eventually I will be putting a 5.3 LS motor in this truck, which would mean a new radiator and electric fans, so I am hoping not to have to buy a new shroud, just to not need it in a few months. I am also playing with the idea of riveting 2" of aluminum to the shroud and extending the shroud that way. The truck is no longer overheating and runs great, but for safety when the hood is open and just to be correct/more efficient, I would like to put the fan into the shroud. Thanks again for the help! Damon Last edited by dgheinen; 05-09-2017 at 08:58 PM. |
05-09-2017, 10:03 PM | #2 |
laying low
Re: Radiator Shroud Help Needed
You definitely do not want to put a spacer behind that fan clutch. If, in a few months, you are planning to do the LS swap you won't be needing that shroud anyway so for temporary use you could rivet say a 4" band of aluminum to that shroud and solve your present issue. That 4" is about the difference between the V8 engine stand location and the L6 location.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
05-09-2017, 11:25 PM | #3 | |
20' Daredevil (Ret)
Agree with Boog, do not add a spacer to your fan clutch.
05-09-2017, 11:31 PM | #4 |
So at 9 1/2", a 4x4 fan shroud would somehow be too long! If mine is 4 1/2", an extra 5" would put the fan too far into the shroud by 1" to 2".
Maybe the bandaid aluminum extension would be the best route for now, until the new rad with electric fans |
05-10-2017, 12:00 AM | #5 |
you want your fan to be just inside the shroud, looks like a 4x4 shroud would work
05-27-2017, 09:09 AM | #6 |
and some time ago, a member posted plans for fabricating a shroud; those were great plans that I can't find now
05-27-2017, 10:33 AM | #7 |
Msgt USAF Ret
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-27-2017, 12:14 PM | #8 |
thanks a lot, that's helpful. someone has also shared plans (that he drew) for a fan shroud that he built from scrap for a v8 engine. I may have seen it on another website. this gentleman shared the detailed plans and photos
05-27-2017, 01:33 PM | #9 |
I extended the shroud on my'71 GMC with a strip of vinyl base molding from either Lowe's or Home Depot. Wrapped it around the shroud and secured it with short sheet metal screws. I KNOW IT SOUNDS LIKE IT'D LOOK AWFUL.... but I don't think it's very noticeable. It's black, about the same texture as the shroud and it has a little lip on the edge. It worked great, made a huge difference in temperature on the truck. Cost less than $5 to cure my problem.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
05-27-2017, 02:14 PM | #10 | |
Think I used Contact Cement and rivets to attach it. Darn thing pushes so much air now that I can still get home by revving the engine up to 3500 RPM if the tranny goes out. ...ok I made that part up. Notice the camel hump fuelie heads? |
05-27-2017, 08:18 PM | #11 |
20' Daredevil (Ret)
An inexpensive solution to a relatively common problem, and it looks good too!
05-27-2017, 10:57 PM | #12 |
Here's a couple more pictures of mine. I have a 7 blade clutch fan that sits a little deeper into the shroud. Runs quiet and COOL
