Old 05-10-2017, 04:59 PM   #1
Big Block
Big Block
Big Block's Avatar
New ride. 86 GMC High Sierra Short Bed
How do I get this crap off without damaging the original metallic paint. Used a heat gun on low setting to pull old yellowed vinyl trim off.
Big Block is offline   Reply With Quote
Old 05-10-2017, 05:24 PM   #2
Big Block
Big Block
Big Block's Avatar
Re: New ride. 86 GMC High Sierra Short Bed
Ditched the bed rails and installed new front break pads. Looks like the old ones were full metallic. They were squealing really bad. Seems like the new pads did the trick. Also repainted the front rally wheels. Still have the rear wheels to do. Rubbed the drivers side paint out. Doesn't look to bad for 31 year-old paint. Slowly but surely get a few things done. Going to replace the front mud flaps with some black plastic ones. Yeah, I know the flaps look like crap but I live on a gravel road and their going to have to stay for now.
Old 05-10-2017, 05:37 PM   #3
RUN GMC
RUN GMC's Avatar
Nice one you got there.............
RUN GMC is offline   Reply With Quote
Old 05-10-2017, 05:38 PM   #4
Big Block
Big Block
Big Block's Avatar
Thanks, any ideas on removing the tape without damaging the original metallic paint?
Old 05-10-2017, 07:37 PM   #5
Jake Wade
Jake Wade's Avatar
There is a special pad that is made for just that. Body shops use them on their air grinders to remove that stuff, doesn't affect the paint. Sorry I don't know the name or a link to it.
Jake Wade is offline   Reply With Quote
Old 05-10-2017, 07:44 PM   #6
RUN GMC
RUN GMC's Avatar
Yeah low heat with a gentle hand to remove glued on trim.......3M makes a adhesive remover in a liquid wipe/rub style and they also have a wheel for a buffer to do the same.......but I have always left it to my detailer to do that kind of stuff for me since they are asked to do it all the time......click on the link below.....
https://www.google.com/search?q=3m+a...hrome&ie=UTF-8
Old 05-10-2017, 07:46 PM   #7
Jake Wade
Jake Wade's Avatar
Here you go. I have seen it in action but never used one myself.
https://shop.advanceautoparts.com/p/...612/10070229-P
Old 05-10-2017, 07:59 PM   #8
abig84
abig84's Avatar
yeah the guys in the body shop at work use something similar to that. i think you still have to be careful, as its just like buffing push to hard or hold it in one spot to long you risk burning the paint. probably practice on the most unnoticeable spot on the truck you can find
abig84 is offline   Reply With Quote
Old 05-11-2017, 08:41 AM   #9
LT7A
I've got one of those eraser wheels. Good call on the link. However, you can probably find less expensive versions than that 3m one, and maybe local. Got mine at WESCO who is the paint supply chain out here. Mine was threaded and I wanted to use a drill motor so I had to get the piece it threaded into that I could chuck into my drill motor. They are pretty easy to use and shouldn't build up enough heat to hurt good paint. When it got hot it started to melt the eraser and leave residue on the paint but the paint didn't care.
Neat truck. My first SquareBody was an '91 that I bought in 1991 and was that color. Have always liked the gray.
Old 05-11-2017, 09:36 AM   #10
Tash4
Tash4's Avatar
i have used the eraser wheel and it works well. 3m has one part #7498, motor guard has one part # e4000s. i use with electric drill and not to fast so it doesn't burn the paint.
Tash4 is offline   Reply With Quote
Old 05-11-2017, 12:16 PM   #11
Big Block
Big Block
Big Block's Avatar
Thanks to everyone who responded. I'll give one a try. I hate cheap plastic trim anyway. Truly sad GM cheaped out and started using that crap. I have a 70 GMC truck with the original aluminium trim on it. Still looks decent. 47 years out in the weather.
Old 05-11-2017, 12:19 PM   #12
daddyjeep
daddyjeep's Avatar
It has been a long time since I used one of those eraser wheels, but if I remember correctly patience is needed. It is not a quick and easy process. Or....I could be wrong. When I used one it was on 4" stripe down the whole side of an S-10 and they were old and cracked.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 05-11-2017, 12:29 PM   #13
Big Block
Big Block
Big Block's Avatar
Anyone have a recommendation for the door glass outside weather stripping? Mine are completely dried out and cracking. Any manufacturer fit better and look like the original part?
Old 05-11-2017, 01:32 PM   #14
Jstock85
Heat gun and a small, thin plastic scraper. I've seen that done before.
Jstock85 is offline   Reply With Quote
Old 05-11-2017, 05:37 PM   #15
bbbc10
Diggin The SquareLife
you plan on keeping the bed rails or sell them?
bbbc10 is offline   Reply With Quote
Old 05-11-2017, 05:53 PM   #16
TKCR
TKCR's Avatar
Precision. There's a vendor for them here on the site.
Old 05-12-2017, 09:03 AM   #17
Big Block
Big Block
Big Block's Avatar
Will post pictures of the bed rails. They're up for grabs if anyone is interested. Driver quality. Some pitting in chrome. No woodgrain on the rails. Will post pictures soon.
Old 05-12-2017, 09:08 AM   #18
Big Block
Big Block
Big Block's Avatar
Will get close up pictures of the bed rails tonight.
Old 05-12-2017, 03:58 PM   #19
bbbc10
Pm me price
Old 05-14-2017, 01:20 PM   #20
Big Block
Big Block
Big Block's Avatar
Thanks for the information. Worked like a charm, worth every penny. I have to go back and try to blend it in. The paint is like new under the trim molding. It's going to be hard to blend it to the weathered paint.
Old 05-14-2017, 01:24 PM   #21
Big Block
Big Block
Big Block's Avatar
Now I have to pull old trim molding on the passenger side and do it. It's not difficult. Just have to work kinda slow. Kind of looks like a ghost stripe on the drivers side. Well at least it's off. I really despise that cheap plastic trim. "If it ain't steel it ain't real" as the old saying goes. Lol
Old 05-15-2017, 09:45 AM   #22
Jstock85
Looks good!
