Old 05-10-2017, 05:45 PM   #1
Duck 37
Unhappy Alternator noise
I have a whinning noise coming from my alterntor,if I take the power off of it the noise stops.The real issue is this is a new unit and I've tried two others. New belt and no sign of water pump problem. At idle its low, but ay higher RPM's you can hear it in the cab Any thought would be appreciated.
Duck 37 is offline   Reply With Quote
Old 05-11-2017, 08:28 AM   #2
biketopia
Re: Alternator noise
You picking up feedback through your speakers?
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 05-11-2017, 09:30 AM   #3
Duck 37
Smile Re: Alternator noise
The truck is bare bones at this time,no speakers.Thanks for the reply
Old 05-11-2017, 10:08 AM   #4
jjzepplin
jjzepplin's Avatar
How is the voltage output?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 05-11-2017, 01:58 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Just pretend it is blower whine...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-11-2017, 09:29 PM   #6
Duck 37
Talking Re: Alternator noise
14 volts across the terminals. I thought it was more like a gear drive.
Old 05-11-2017, 10:30 PM   #7
Wrenchbender Ret
A shorted diode will make it whine like a bad bearing, but you say you have tried other alts. This is a tough one.
Wrenchbender Ret is offline   Reply With Quote
Old 05-12-2017, 01:01 AM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
I've got the same gripe on the last 2 alternators on the L6 292 in my '68 C/10. I replaced it with one ''lifetime guarantee'' alternator [external regulator type] from O'Reilly's.
New one on and same whine, same red GENERATOR light in the dash. If I rev up the RPMs, and let it settle down, the whine and red light go out, until the next light. I may have to shim one of the pulleys in the front. It's possible the belt's misaligned.
I'm thinking of getting a 12SI alternator. Getting a good vintage alternator out of O'Reilly's was like pulling teeth. Never had that problem when they were Checker Auto.
Old 05-12-2017, 09:19 AM   #9
Duck 37
The fellow who rebuilt this alternator is a personel freind and has been in the business for 20 yrs. He's scratching his head. He's making a house call to my place today. Has to be something in the truck,it started after I bought it with the old unit.THANKs for all the replies.
