All about them K’s
![]() Join Date: Jun 2014
Ord steering box frame repair 67-72
Any body have pictures of the ord frame plate kit on a 67-72? I got the kit in the mail today to fix the cracks in my frame and it doesn't fit worth a crap. I know it's intended for a square body but the site says it will work with the 67-72 trucks as well. It's gonna take a lot of work to get the lower plate right and the bottom rear corner of the side plate is way off too. Post up what you got! Thanks!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
![]() Join Date: May 2012
Re: Ord steering box frame repair 67-72
I had a link to this article. I considered one last time my box was out. But I never pulled the trigger because I have not actually seen a crack. Hope someone can chime in for you.
https://ck5.com/forums/resources/ord...repair-kit.62/
White K20 |
I put one on mine a long time ago. No big wup. Just cut to fit. A little opening up of one of the holes near a rivet if I remember right. No pics as it is assembled now.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#4 | |
All about them K’s
JJ- That's about what I figured. I just wanted to make sure I wasn't missing anything, because everything is way different on the bottom plate. I'll fire the plasma up and do some trimming...
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 05-11-2017 at 09:34 AM. |
There is also one that goes between the frame rails and connect to the rear side of the steering box. That one looks to be quite strong as well. Both together would prove to be very unlikely to have a failure. Although I have been pleased with just the plate unit. My frame started out with no cracks. I then totaled the truck bending the frame and front springs. Still no cracks at the plate. Cut it off and installed it on my other truck. SOlid performance.
