Old 05-10-2017, 07:08 PM   #1
ebaby35
compatible Rear end for 64'
Hey I know this question has probably been asked a million times but im confused on what can work and wont. I would like a rear end that doesn't require me to move the perches but thats not a must. I would like to find one that is 5 lug and have disc brakes. Im going to be going to the junk yard and need to know what to look for as in what years and types of trucks will have this. I dont mind having to relocate perches just need something same width. I sold my 12 bolt and yes I know it was mistake.
ebaby35 is offline   Reply With Quote
Old 05-10-2017, 07:35 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: compatible Rear end for 64'
The one in the 64 is a 12 bolt truck, strong! You can change the axles to 5 bolts.
Old 05-10-2017, 07:42 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
The easiest way to do what you want is to buy new axles (5 lug) from a supporting vendor for the 12 bolt you have, rebuild while your there and add disc brakes to the 12 bolt, hit up Captn Fab her on the forum on what to buy.
Oh, you will also need a new prop valve or master for disc/disc brakes too.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-10-2017, 08:01 PM   #4
ebaby35
dont have the one that came with it I sold it and regret selling it.
Old 05-10-2017, 08:03 PM   #5
The Rocknrod
Moderator
Originally Posted by ebaby35 View Post
... I would like a rear end that doesn't require me to move the perches but thats not a must. ...
What rear end do you have now?
Old 05-10-2017, 08:08 PM   #6
PGSigns
PGSigns's Avatar
I would look for another 12 bolt and just update it. That would be your best approach.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-10-2017, 08:14 PM   #7
ebaby35
had a 62' frame then switched to 64' and sold the 62 rear end and bought a 96' caprice rear and sold it. Just a lot of bad decision making
Old 05-10-2017, 08:17 PM   #8
Clyde65
Clyde65's Avatar
We have all done that.
So, find a 12 bolt from a 73-80? 1/2 ton truck and get Captn fabs coil rear mounts (you do have coils right?) then have someone or you cut the leaf mounts off and weld the coil mounts on. That will be the least expensive.
Good luck!
Clyde65
Rebuild of Clyde
support our troops!
Old 05-10-2017, 08:21 PM   #9
ebaby35
no coils going to do airbag
Old 05-10-2017, 08:53 PM   #10
Clyde65
Clyde65's Avatar
Ok but you HAD coils right?
Clyde65
Rebuild of Clyde
support our troops!
Old 05-10-2017, 09:02 PM   #11
ebaby35
yes... I dont mind modifying something just trying to get a good deal at a junkyard and something that can be made to work
Old 05-11-2017, 08:22 PM   #12
ebaby35
I have someone selling a 1973 dana 44 off a blazer could that work and how do they compaired to 12 bolt?
Old 05-11-2017, 11:34 PM   #13
Captainfab
60-66 Nut
A '73 K5 Blazer would have a 12 bolt in the rear and a Dana 44 in the front. This is if it is a 4x4.
I would go with a truck 12 bolt over a Dana 44 any day. A 8.5" truck 10 bolt isn't a bad differential either.
Old 05-12-2017, 12:18 AM   #14
ebaby35
Would a 1985 burb 2wd have 12 bolt or 8.5 and those be made to work without narrowing
Old 05-12-2017, 11:41 PM   #15
Captainfab
60-66 Nut
The last year for the truck 12 bolt was '82. So an '85 Suburban will have the 8.5" 10 bolt. It is 1.5" wider than the 12 bolt in your '64. Many people use the '71-'87 differentials under their '60-'70 trucks without issue. However it will depend on what rear tires you plane to run.
Old 05-13-2017, 10:39 AM   #16
norust
norust's Avatar
i got a 12 bolt '71 1/2 ton rear end with ladder bars that fit a '66 SWB frame for my project build.
I am going air ride
norust is offline   Reply With Quote
Old 05-13-2017, 04:23 PM   #17
ebaby35
Thanks for all the help, I ended up just getting a 69 12 bolt for dirt cheap that ill rebuild
