When I signal left all the lights flash
I was about to add a connection for towing when I ran across a bunch pinched and frayed wires. I started repairing some of the wires when I noticed that when I signal left all the lights flash like Hazzards. I did add a Hazzard switch but only the right side works. Any thoughts?
Re: When I signal left all the lights flash
Sounds like a grounding issue. Clean and check all grounds. I had a similar "funky" issue and couldn't figure it out until I made sure all grounds to the lights were solid. Redid the tail lt buckets and viola. Hope this helps.
60 K20, eaton HO52, T221, SM420, Dana 44 closed 78 K20 Burb, 14 bolt, NP205, SM465, Dana 44 open 05 Dodge Ram 2500 5.9 Cummins 4x4 |
Thanks Vondog,
I guess I know what I'm going to be doing all day tomorrow. |
