Installing GMC Paul polly rear tank?
So i have kind of been out of the hobby for about 4 years. Before I had stopped working on my truck i had ordered a rear tank and i'm thinking it was from gmc paul. its the same tank as far as i can see. My problem is i cant seem to figure out how these straps are supposed to hold this tank in, what am i missing?
The one strap is different then the other and i have been searching the forum all night for an answer. Also i thought the tank would fit a little tighter between the frame rails?
My 67 GMC Balls to the walls build- http://67-72chevytrucks.com/vboard/s...d.php?t=268195 |
Re: Installing GMC Paul polly rear tank?
Dude the sending unit retainers are classic.
I don't see anything to hold the tank in place on top to allow the straps to do their job.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Would they circle around and mount to either crossmember?
1971 C10 Long Bed 1972 C20 Long Bed |
Looks like you might be missing a couple of straps?
"I pawned my Hanso" "Hold my beer, Watch this" |
#5 | |
I was just on the brothers website and they have a video on how to install the rear tank. They have one on the poly tank and another on the metal tank. I think this will help you out some. Last edited by old51sedan; 05-11-2017 at 07:12 PM. Reason: Additional Information |
#6 | |
I am a Referee of life.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
So as im reading these reply's and checking out the info on the Brothers site like old51sedan suggested i realize they bent the straps whatever which way so they would fit in the box to ship
![]() My tank still doesn't fit very well between the rails though so prob going to have to box it in some how. Ill get to work and post what i come up with.
scrap it , and get a Boyd welding tank
mike |
It crossed my mind. Regret not getting a top fill tank.
I added a little extra to the frame where the tank meets. You cannot tighten the straps too much or the tank will deform. No rust will form in a poly tank. Or the aluminum for that matter.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Im thinking i will do the same. do you have the same tank? If so did you bolt the straps to the frame rails on the one side and then use the hardware provided (hooks) on the other side of the straps?
#13 |
My straps had no hardware as the poly tank was used.. I welded a small tab to the bolt head so it wouldn't spin in the frame and tightened slowly.
Posted via Mobile Device |
#14 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Straiten the straps out. They are only bent that way for shipping. Bend them around the bottom of the tank so they are even from left to right. The "J" hooks you should have received with the tank will hook the bottom of one side of the frame or the other. (doesn't matter witch) You will need to purchase additional bolts to use for the opposite side of the frame. You will have to drill holes for the bolts and "J" hooks. Hope this helps. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#15 |
I bought a similar tank from a board member, he got it from Amazon. Mine has a type of ledge on each side that the straps hold the tank to the frame. I mocked it up with the hooks to see how long i should have them. I used an additional bolt and washer on the under side of the frame rail. I had to drill two holes and used two oval holes. I installed mine today, if I started over I would use longer bolts, 2inches, to make it easier for the nut to grab.
#16 |
Thanks for the replys.
Ended up getting the tank in this weekend. I used some angle iron i had and used it to keep the tank tight between the frame rails because i didnt like how it could move around and potentially pop up past the rail if it moved over to one side.
#17 |
Before and After
Now that I see that picture, that is how I had to install mine as well, although mine was a steel version. Nice work
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
