05-11-2017, 12:06 PM | #1 |
Measurement of Glass In Window Channel
I should have taken photos of my old glass before I removed it from the window channels. Now, I am installing new glass and want to get it right the first time. I remember the glass went past the end of the channel shown in the photo by about 1/8" - 3/16".
Could I get someone to please take a picture and get a measurement of the glass installed? I would really appreciate it. POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
05-11-2017, 12:28 PM | #2 |
Re: Measurement of Glass In Window Channel
Once everything is installed in the door and working I lift up on the glass and lay a bead of windshield urethane in the track , set the glass in and roll up the window check fit and seal all around and let it sit over nite , it finds its own "happy place " and works everytime for me
05-11-2017, 12:46 PM | #3 |
Thanks Grumpy. Right now the doors do not have any of the channel fuzzies or vent window assemblies installed. The vent windows are new and they do have the fuzzies in them.
Do you think I could install everything into the door as if the glass was glued in, then roll the glass up far enough to be able to lift it and put in the urethane? Will the glass be high enough to be able to lay the urethane? Thanks, POP
05-11-2017, 12:52 PM | #4 |
like this...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-11-2017, 03:03 PM | #5 |
Thanks Rob. That helps a lot. I believe I can get the glass urethaned in real close to this and then roll the window up good and tight
POP
05-11-2017, 10:28 PM | #6 | |
some a lot . |
