Not sure what I purchased
Bought a "new" 68 GMC 1500 last weekend from the second owner (he new the original owner who sold it to him in 1980. Most everything was kept factory. I am trying to understand what it was as the rear suspension in leaf where most were coils according to the parts I am finding. Also the vin number doesn't match any decoding I am finding.
CE10DP-B45093 Anybody have suggestions in what I have? Thanks |
Re: Not sure what I purchased
What does the SPID on the glove box door say?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
laying low
![]() Join Date: Mar 2001
Leaf springs were standard on Gmc and coils were optional. Just the opposite for Chevy.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
![]() Join Date: Oct 2011
Where did you get that VIn number from?
As demian said....check the 'SPID', which is the info/option list on the inside surface of your glovebox....hopefully it is still there, intact and readable. It has the VIN on it and that should match the stamped VIN on the riveted plate within the drivers door frame. As for the rear leafs, back then GMC standardized on having 'rear leaf' suspension as the standard suspension...with trailing arm/coil as an ordered option only. Chevy was the other way around...they standardized on having 'coil' rear suspension with 'rear leaf' as an ordered option. Your truck having leafs is pretty common on GMC's and if you plan to haul anything it is a better choice. If you get a chance post up a few pics...including pics of that (inner glovebox) SPID sheet....and we will be able to help you out more. Welcome. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
Thanks for the information on the leaf springs. There is no SPID tag in the glovebox. I do have the original owners manual as well as the owner protection plan with the engraving plates for the original delivery with the original owners name. The Vin # on that steel plate (attached to the protection plan manual) matches. here is what was on the stamping plate:
307 0000 CE10D-PB45093 RXSTD 3.54 1D156018 TRAT400 GMC2 it was originally in Idaho. Not set up to attach photos yet. Will need to look into that more. thanks |
GMC's in 68 did not have SPIDS ! at least the ones I owned did not ! Leaf springs came standard equipment . Google GMC 67-72 lots of VIN decoders
71 C-20 07 Magnum RT AWD |
Thanks everyone, I was able to find a vin decoder with GMC codes. Most of the ones I was looking at showed they were the same as Chevy which clearly they are not.
I plan to slowly work on this with my two kids and let them drive it when they get their old enough. I think I will get lots of good information from this site. Probably an overload but too much information cant hurt right. |
