Transmission Help
Hey Guys. Ill Try to keep this short.
Im building a lifted 69 C20. here's the link if you wanna check it out. http://67-72chevytrucks.com/vboard/s...d.php?t=728388 Doing a 5.3 LS and 4L60E Swap I pulled out of a 2000 Tahoe in the junkyard. The motor starts and runs, seems fine but thats all i know. it has about 200k on it. I wanna run it as is, no mods and hopefully nothing major to repair. I opened the pan on the trans and there was a ton of clutch material in it. So im trying to figure out what to do. I have thought about building it with my brother BUT we have never done a trans, and we are really strapped for time. This truck is the only thing standing in my way of buying my first house with my Fiance. So trying to get it done which means I dont think well be able to build it ourselves. I've quoted several shops and the best shop reviews and price I've come by are ProTrans in Riverside CA. they quoted $1200 worst case scenario "maybe better if nothing major is broken" with a one year, 12,000 mile warranty. If i want a 2 year 24,000 mile warranty its an additional $245.00. the owner asked that once the truck is done, i allow them to road test it. Im okay with this. With that being $1500 it lead me to find this website https://www.bestbuytransmission.com/...FQqDfgode5kPDg They offer a 5 year warranty for about the same cost but they are re-manufactured. I cant seem to find any info on them and was hoping someone might have experience. . There is guys building them on EBay like this one.Not a whole lot of reviews but the reviews they do have are positive. components look good though. http://www.ebay.com/itm/4L65E-4L60E-...RXFvbk&vxp=mtr the last option I have is a shop called California Transmissions "have excellent reviews" has offered me a deal of $700 cash without warranty because he claims since its a swap i have a higher probability of having electrical issues or just issues in general. ANY input would be great. I have always had issues with transmissions in this truck before this ls swap and I would like that nightmare to be behind me. I wouldn't mind paying top dollar for a trans but the issue is I still dont know if the motor is gonna have any major issues. I've done the run test but it has not been installed and driven. I know, cheap inst good and good inst cheap but im trying to be budget minded. |
Re: Transmission Help
Go with whomever you feel most comfortable. I'd personally go with a company that has lots of reviews and a good warranty (read the fine print, some warranties don't cover anything unless it's in the original vehicle). If budget doesn't allow, go with whatever you can afford, but be cautious. A shoddy shop that will sell you a cheap trans may not give you anything worth installing.
Good luck!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
![]() Join Date: Jul 2016
So your going to spend about $1500 to fix a problem that you don't even know exists?
Good way to go broke... What are you out if you just install the transmission and then see if it needs work? Automatic transmission wear and deposit stuff at the bottom of the pan...its the way it works or do you think when it was in the truck before it arrived at the scrap yard they were cruising around in it with a transmission that was bad? With that kind of swap you have so much money to spend on install parts So much labor that is crazy and your worried about having a perfect transmission? Just put it in and sort out stuff. Your sort out list is longer than my reply. |
And I would just buy a brand new GM trans for whatever the cost is, rebuilds just don't last that long in 4 speed GM autos of the small block variety.
#6 | ||
#7 | |
I agree buy a new transmission (not rebuilt, the price difference is not enough to justify a rebuild). The new car 700r4/4l60, whatever you want to call it usually lasts 100k to 200k, the rebuilds last small fractions of that, parts wear in those that cant be rebuilt. If I were you I would use the very cheapest trans fluid and the old filter to test the transmission. And since you know the fluid costs $100, you should have just tested the trans by installing it. You asked for opinions, you got an expert one.... |
#8 | |
Usually a used trans still has some kind of warranty. Might not be much but they usually stand behind them. I would contact the junk yard and find out if it has any warranty 1st. I just looked at car-parts.com and used ones are going for 350-700. All depends on how much you want to spend. You already have the trans could just try it and see if it works. All you will be out is fluid and time.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
#10 | |
#11 | |
Think of this though.... At a minimum you have the following problems to solve and whether you can finish them or not. Also most projects never get finished, I would say the percentage is less than 50% at 5 years down the road. Even drivable at 5 years not just starts and goes in gear. Engine and trans mounts Driveshaft Throttle linkage, fly by wire right? Pedal mount, wiring, fit feel, etc. Engine management wiring Fuel system wiring which is usually separate from engine management, at least part of it High pressure fuel system, you will probably put in a new tank too Return fuel line Cooling system configuration for engine to truck, hoses, lines radiator and fans Power steering pump, both lines need mods for the truck You have a lot of systems to find buy and install. If you finally got all of them and the trans worked even marginally you would be considered very successful. |
#12 | |
