Late models 6-lug wheels
What thickness adapter/spacers are required to run late model (6-lug) wheels?
Thanks!
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#2 | |
Re: Late models 6-lug wheels
I am concerned about offset.
I run 22x9 GM Transit wheels with 6" backspace which I believe are the same specs as the nicer late model wheels that replace them after shipping. On the front, I have no spacers and they fit perfectly. On the back, you need to run at the bare minimum a 1" spacer or else they will hit the inside of the wheel tub.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
I have a 2" spacer on mine all the way around. running newer gmc stock rims
I have 265 / 55/ 18
Can I have more then 24 hours in a day I need about 2 more please Last edited by chebbylove; 05-12-2017 at 09:50 AM. |
#5 | |
#6 | |
#7 | |
Correct. I didn't originally mention that because you said you had wheels with a large center bore. I think if you have a front disk conversion, the fronts will fit without being bored.
I am a Referee of life.
Boring the heels never made much sense to m. Why not turn down the center of the hub so that any later wheel would fit. I don't like spacers very much but it' up to you.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
For me, it was either go through the hassle of turning my hubs, or just pay a few dollars extra and have the center of the wheels bored by the guy I bought the wheels from. I don't plan on putting anything other than steel wheels on my 6 lug setup, so it doesn't matter to me that no other modern 6 lug wheels will fit. In general though, I agree, have your hubs turned so that you have some freedom to change things up in the future.
hewitta. did you get the wheels local here in Winston? Or did you order them? Thanks for your time.
I got them from a guy I met on Instagram. He has more sets, $650 shipped.
#13 |
