Old 05-12-2017, 12:13 PM   #1
ncr8rfan
1971 C-10 Steering Wheel Issues.....
Having some issues swapping out my stock steering wheel with one off a 1978 Camaro. Can not get the horn to work as it should. Works fine until I tighten the screws then it stops working as it should which is when pressed. Am I missing something here. Am I suppose to have something to add to this installation?
ncr8rfan is offline   Reply With Quote
Old 05-12-2017, 04:03 PM   #2
Wrenchbender Ret
Re: 1971 C-10 Steering Wheel Issues.....
You may have the wrong plastic spacer that the screws go through. You might have to put small washers under each tube to raise it a little.
Wrenchbender Ret is offline   Reply With Quote
Old 05-12-2017, 07:20 PM   #3
ncr8rfan
Thanks I'll try that tonight
