Old 05-12-2017, 03:38 PM   #1
Cris
Panhard (Track) Bar Bushing Removal
How tough is it to remove these bushings? I have done a search and people talk about burning out the rubber, but you still have to contend with removing the outer metal sleeve. Is it just a hack fest? Or is there some easy technique to coax them out?
Also it looks like Brother's has GM original replacements.
Thanks, Cris
Cris is offline   Reply With Quote
Old 05-12-2017, 03:43 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Panhard (Track) Bar Bushing Removal
I actually did this with a C-Clamp and a Socket, think about that for a minute or two and you should be able to figure it out I don't have a picture.
Old 05-12-2017, 04:37 PM   #3
Cris
Rocknrod:
Thanks. That at least bodes well that they may press out OK. I'm just concerned that the outer metal sleeve after 50 years will be a little reluctant to slide out!
Regards, Cris
Old 05-12-2017, 05:56 PM   #4
The Rocknrod
Moderator
What are you replacing them with? Have a link or pic?
Old 05-12-2017, 06:40 PM   #5
Cris
http://www.brotherstrucks.com/63-72-...tinfo/OETAB72/
I'm not a fan of poly for stock type use, would prefer rubber bushings.
Old 05-12-2017, 06:47 PM   #6
The Rocknrod
Moderator
How good are you with a torch?
Old 05-12-2017, 06:52 PM   #7
Cris
Capable with a torch, but will try to press them out first. If that doesn't work I'll get down and dirty with it.
Old 05-12-2017, 08:09 PM   #8
PGSigns
PGSigns's Avatar
I took a hole saw and ran it through the rubber. Left mostly the sleeve. Then just took a sawsall and put a slit in it and drove it out with a hammer and chisel. Did not take long at all. Did the trailing arms the same way. I have a shop press so went back in with that.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
