1966 C10 3"coil drop question on the camber alignment
Hey All,
Had a question. Has anyone put on a 3" drop coils in the front of there C10? Mine is a 66 C10. And I am trying to find out if the camber can be set correctly with a 3" drop spring. I am planning on 2.5 inch drop spindles as well, but that is in the tow though... My main concern is the camber which is set by the coil height. Please let me know if anyone has actually put 3" drop coils on a 66 C10 front end with a V8 and set there front end alignment and it was able to be set correctly thanks.... |
![]() Join Date: Jan 2011
Re: 1966 C10 3"coil drop question on the camber alignment
When I did the a arm swap on my 66 I did 2" springs and 2 1/2" spindles. That was the max I could do with 15" wheels and still had to grind the lowers. I put the studs out of the donor truck for the upper a arm. They are a about 3/4" longer than the stock ones and allow the added shims needed to be put in and should allow for the 3" springs.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Hi 64jmb, now that you have me wondering, I went out and set my wheels as straight as possible and took a good hard look at the camber on my wheels and they do look like I might have a tiny bit of positive camber, which means that my outer corner of the wheels would wear quicker. I still have about 3 shims on each point that I can play around with but I really believe that if I took my truck in to get adjusted, it wouldn't be much. I've always adjusted the toe in/out and all that stuff by feel on my old cars and trucks and for my buddies a few times. It takes a few test drives but I get it to where it "feels" right and then just keep an eye on the tire tread. I had a 54 Caddy one time and rebuilt the whole front end and took it to several places to get it on the rack and computer adjusted. Everywhere I went, I was told they couldn't touch a vehicle so old as it was a liability issue. So, I said fine, adjusted it the best I could by "feel" and eyeballin' it in my driveway and drove it around for years on a set of bias ply whitewalls and never had a problem with uneven tread. Oh yeah, I cut the coils on that giant monster too.
#4 | |
#5 | |
its Joey....Ya my tires would wear on the inside a bit.... yours on the outside? ...He said he had no shim left to work on the camber with at what the springs were cut at. So I am guessing they have to have been cut at 4"inches or more....? Do you think that is what they were cut at? 1.5 coils is what he said he cut them at... thoughts... |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Yes. I did it on my 63. I used 3 inch coils and 2.5 spindles. No issues with alignment. There was plenty of stud length for sufficient shims.
Awesome can I see a side view of your truck and is the tire tucked up in the fender well? Send me a picture for the side! Thanks!
You will need to cut down the bump stops. An arm swap is when you swap to the 73-87 stuff. I have done this on my last few trucks. It gives little bigger ball joints, tie rods and rubber bushings in the control arm shafts. It can also give you 5 lug and disc brakes at a low cost. A good donor truck gives you the power steering stuff and all the suspension parts.
Jimmy
I already replaced the ball joints they were bad. I have the CCP stuff on my truck now 73-87 6 lug disc brake set up and my conversion is done I am changing them to 2.5 drop spindles and 3 inch drop springs. Someone just said they did this on there 63 and it all just bolted it in. My springs were cut allot like over 4 inches I think 1.5 coils cut each one does that sound right?
2 1/2 drop spindles 2 inch coil everything is a bolt on.
#13 | |
I really had a few more confirming questions I really needed to be answered before I exchange my springs and install all this. 1. Is the 63 to 66 suspension the same? You had no modifications at all? No cutting or shortening or anything like that? 2. You used 3 "drop springs, and 2 inch drop spindles? And, just installed the 3" drop springs and 2.5 drop spindles and it all went in ok no additional modifications or changes that needed to be made? What brand were they CPP? Classic performance Parts in CA? Do you have a picture I can see a side view of your truck? What is the height from the ground to the bottom of your wheel lip moulding? Mine is 26 7/8 inches now and I really want to keep it like that. Is that what yours is? Let me know thanks Last edited by 64jmb; 05-20-2017 at 09:54 AM. |
#14 | |
You're stressing out on this deal. It's a proven swap. There are a group of us on here who have done it countless times. Lolife and Scoti come to mind. If it would make you feel better, post these questions over in the suspension section and run it by those guys and see what they say. Just remember, some guys have done the work lots of times so their answers should carry weight. Some guys "have heard" or "have read" and they throw out answers that shouldn't carry the weight of experienced guys. Seriously, post your questions in the suspension section. It will make you feel better to get a wider audience to help with the answers.
#15 |
Moderator
![]() ![]() Join Date: Aug 2011
Thats funny I bought a set of Western Chassis spindles found out Western and POL are the same company.
#16 | |
#17 |
I don't have any way to measure. I never keep my trucks very long. Just build and sell. The 63 has been through several owners since I sold it. Last I saw it had air suspension and camper.
#18 |
ok thanks appreciate the help!
