Which cam for LQ4?
Ive got an LQ4 for my swap, my current motor is a small block with a 270/470 comp cam. Im looking at a comp cam thumper, which one compares to my 270/470? It has to sound good and make HP, around 450HP is what I'm looking for. The other mods Im still researching. Ive never had a roller cam so I don't know how how they compare.
Post Whore
![]() ![]() Join Date: May 2015
Re: Which cam for LQ4?
Your gonna need more than just a cam swap to get 450hp from a lq4..the lq4 stock is around 320s hp..as far as a cam I'm fixing to drop a btr stage 2 or 3 in mine..they sound great..lookum up on utube for sound
Those thumper cams aren't performance based. They are ground for sound.
We put a 6xx/23x/113 cam in my brother's 243 headed lq4 (I cant find the original specs). I recommend calling up any of the big cam companies and tell them what you have and they will recommend a specific cam to match your needs.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
Post Whore
Check this out..http://www.superchevy.com/how-to/eng...-makes-464-hp/
#5 | |
![]() ![]() Join Date: Oct 2014
#6 | |
and checking those links now........ |
What are your plans? Daily, towing, street performance, stall converter?
I would mill the 317 castings .030 and then discuss your cam specs and spring selection with someone like Cam Motion, Engine Power Systems, Brian Tooley, LS1tech has more reputable vendors. Quick google search for something I would put in your ballpark. 224 at .050 is good compromise on sound, tq, and drive ability. https://www.youtube.com/watch?v=HCwolKH6RNA |
meowMEOWmeowMEOW
That article feels that the Comp lifters (their donor sponsor) are of "better quality" than the GM LS7 lifter, a part so praised for its design that it actively replaced the entire back catalog of GM LS lifters and superseded all their uses in GM TSB....
...Seems legit.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() Last edited by BR3W CITY; 05-15-2017 at 07:56 PM. |
Post Whore
Gotcha sdave..I weighed building a engine to hit the 450 mark vs ls3...I went ahead and found a good low mileage ls3 for less than what I could build a engine for...426hp stock..close enough for me..
#10 | |
It's gonna get the mill, the compression is definitely gonna have to come up |
Compcams recommended the 54-457-1, said it has a rough idle and good performance. Anybody use one of these? I found some videos online but the idle sounded only slightly rough, granted it's the internet and I only found a few videos but I was hoping for more sound
Does it have more? |
Texas Speed MS4!!
![]() In all seriousness, call an LS performance company like Texas Speed, Tick Performance, Cam Motion, etc. and tell them what you have, what you plan to do with it, HP and performance goals. They'll help you pick the right cam and other complimentary upgrades to go with it.
#13 |
meowMEOWmeowMEOW
FWIW if anyone cares about the tech side of things. Cams are a little like batteries, in the sense that only like 5-6 companies actually MAKE cams;the rest of them either order cam cores and grind their own, design their profiles and have them ground at a larger scale machine shop, or simply license an existing profile with an existing company and slap their name on it for a fee.
Comp is the BIG player (they own 80%+ of the common performance brands you've ever heard of) and they are also the #1 cam core maker in terms of volume. The problem is that over then last 2-3 years the quality of Comp's hard product has fluctuated. We've been witness to 2 separate incidents of cams made (and ground!) by comp which caused catastrophic damage because the lobes WEREN'T TREATED after the grind. Without this, the lobe surface is soft and mars when contacting the lifter and wears down VERY quickly...resulting in flattened cams and the collateral damage that comes with them. We've opted largely to use Cam Motion cores more frequently in the last year as a result. I don't mean to seem super sh!tty on Comp, its just that A) big player in the market is a big target B) legitimate change in quality C) their clearly sponsored influence on the article. ![]()
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#14 | |
I was reading this again and thinking about cams, a 230/230 110 may work giving you the torque to move the heavy truck and the sound you want. https://www.youtube.com/watch?v=a4D8tbWDd6Y EPS is Engine Power Systems which will show in a google search, and they use Cam Motion to grind their cams last I heard. |
#15 |
thx guys
#16 |
A video of my 84 starting for the first time in 9 years, well actually the second time I couldn't believe it started so easy after sitting so long so I shut it of and got the phone out. Poured a cup of gas in the carburetor, cranked about ten seconds and she started right up!
The float is trashed so I had to work the pedal to keep it running and get into an idle but at the end of the video you can hear the cam's true sound with open headers https://youtu.be/4IsjX-7bGcw |
#17 |
EPS has a grind that is 230/238 that they like to push towards the 6.0l crowd. I run a 230/232 112+4 in my LQ9 based Z28 engine. It's got very good mid and upper range power, and a nice big flat torque curve. It will spin 7K rpm but stops building HP around 6500. My car puts down 425 to the wheels through a T56 and 4.10 geared 8.8 rear axle.
You don't have to over cam and use huge lift to make good power. Both intake and exhaust on my cam are under .600.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop Last edited by OutlawDrifter; 06-09-2017 at 08:48 AM. |
#18 |
![]() Join Date: Aug 2014
Call Brian tooley racing, ask them guys. You can thank me later lol
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
#19 |
![]() Join Date: Feb 2004
Im with br3, the cammotion cams have alot softer lobes than comp as well, meaning they dont snap open and closed as aggressive, therefore they are much easier on valvetrane. Also to adress some of the other post made. It seems the OP is wanting 450 at the crank not whp and yes that can be had all day long with a cam change on a lq4. Infact what you need to consider is about a 230/236 ish cam with @.600 lift. You will need a 3400-3800 stall and atleast 36# injectors, im running a sinnister grind that is about this range. I went with 42# injectors for room to grow, the ecm can pull up to 50% fuel so you can get away with a little large. The stock injectors on a lq4 are at 80%+ duty with just a tune....so injectors are recommended for a larger swap. I have a youtube page under disciple77.rc you can see sound clips of both a 221/226 cam and the 230/236 cam and hear the difference. I have not dynoed my truck yet so i cant really make a claim...but I can tell you there are atleast 3 dyno vidieos of the exact cam i have making 400-425whp in a 5.7 ls1. One has heads too....so its a bit more
I would also recommend running a fuel pump that will support the hp you are trying to achieve...
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
