Old 05-13-2017, 10:41 AM   #1
53Brewster
Intro and OEM fan set-up question for 1988 454 one ton dually
Hi All - Dave here, new to this forum. I have a few older trucks, but I am working on two late 80s square body one ton 2WD Dually rigs.
One of the rigs is a 1988 Camper Special that was missing its engine and tranny when I bought it. I swapped in a 454 TBI that was readily avaialble and all is running well. I am now working on the A/C hook-up and I am tackling the A/C condensor and radiator shroud area to ensure I have the right cooling set-up. I am struggling finding a replacement radiator fan shroud and I am scratching my head at this point.
So, here's the question:
Is it possible that this truck had an OEM Electric radiator and a/c condensor fan set-up from the factory?
Thanks a ton in advance.
Dave
1988 Crew Cab Dually
1989 Crew Cab Dually
53Brewster is offline   Reply With Quote
Old 05-13-2017, 12:56 PM   #2
kwmech
Re: Intro and OEM fan set-up question for 1988 454 one ton dually
No it would have been a mechanical clutch fan with a shroud.
Old 05-13-2017, 03:36 PM   #3
SCOTI
SCOTI's Avatar
The shroud assembly is a unicorn. I ordered replacement pieces from LMC for my 89 (both the shroud + radiator top cover) & neither was correct/matched the OE stuff. I just had to clean up my OE stuff & go w/it.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-14-2017, 11:19 AM   #4
53Brewster
Thanks for the follow-up. My thought at this point is to buy a new radiator (planning on it at some point anyway) and match the aftermarket shroud to that. Is this possible or am I up against the same issue?
Thanks again,
Dave
Old 05-15-2017, 12:49 AM   #5
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Factory setup with a.c. would have the water pump mounted clutch fan and shroud as well as a small auxiliary electric pusher fan mounted to the frontside of the core support on the passengers side.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
