![]() Join Date: Sep 2002
front swap ???????
I know it,s been asked before . will a 76 half ton rear end fit in a 68 half ton are the width from backing plate to backing plate the same. can i buy the trailing arm brackets and coil supports and just weld them on . thank,s biglou
Certifiably crazy person |
CCRider
They make a weld on kit with everything you need, Chevyduty has it in their catalog...I'm sure other venders have it as well
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
Fabricate till you "puke"
the width of the 76 diff is approx 1 1/2" wider than the 68(not enough to worry about). http://www.classicperform.com/produc...ersion-Kit.htm Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
