Old 10-21-2003, 03:10 PM   #1
webhendrix
removing door panel cover
A easy quick question about removing a door panel.
I have a 1968 with like the foam/rubber arm rest. I have everthing disconnected except the arm rest. Whats the best way to get that off?
I used a screw driver but could not get anything to turn. I'm down to the ideal of drilling the head of the screw off but I can't see what I'm doing. [don't know what I'm doing / not even sure it's a screw]
Thanks for any ideals in advance.
P.S. I love this web site and surf to it most everyday to read all the good info.
webhendrix is offline   Reply With Quote
Old 10-21-2003, 03:42 PM   #2
photoglg
photoglg's Avatar
Did you use a phillps, the two screws are phillps and the nuts are snapnuts.
1969 GMC S/B S/S 3" drop
photoglg is offline   Reply With Quote
Old 10-21-2003, 04:00 PM   #3
webhendrix
Yes, I used phillps but could not get it to turn. I even tried to pry it out from behind the panel to pop the screws out but that didn't work.
What's a snapnut?
Now that I have a little room behind the panel I guess I will try some penetrating oil next
- - - Oil worked, I got the arm rest off!
Now to work on the door handle button that was pushed in sideways (door won't stay closed, latched) and the window which hadn't moved up or down in 20 years [so far the run tracks look new, I guess I'll oil the commponents and work it]
Old 10-21-2003, 04:16 PM   #4
C10Squared
Get yourself a flashlight and look to see the head of the screw. Just because these started out with phillips head screws doesn't mean that they are still in there. 2 of mine were flatheads.
'72 Chevy Custom/10 Shortbed
'77 2wd K5 “Halfbaked”
'93 Indy pace truck
‘70 GMC Jimmy
‘76 K5 Blazer
Follow me on instagram @C10squared
C10Squared is offline   Reply With Quote
Old 10-21-2003, 04:29 PM   #5
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Mine were philips. Use lots of penitrating oil. Best bet would be to use a rachet with a philips head. Your gonna need the leverage the rachet gives. I personally used a screwdriver with some channel locks for my extra leverage. it is tough if they have been in a while.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
