Old 05-15-2017, 12:37 AM   #1
dtkarst
Air Cleaner Blues...
Im having issues with the air cleaner on my 69. I bought it with some little aftermarket one on it and Id like to get an original air cleaner and spacer together. The air cleaner i have isn't quite right, and I believe I could use a spacer. I have a tube/hose coming out of the passenger side valve cover close to the firewall that doesn't line up with the port on the air cleaner. It is a 2 barrel and I don't have a spacer. Heres what i got if someone could tell me what I need..I think (correct me if I'm wrong) I have a set up for a non ac pickup. but heres what Ive got.
dtkarst is offline   Reply With Quote
Old 05-15-2017, 06:40 AM   #2
terry b
terry b's Avatar
Re: Air Cleaner Blues...
Why don't you move the hole for the breather. If it's round buy a step drill that will cover that hole size. If it's square drill small holes in each corner and cut out with tin snips. The old hole won't matter.
terry b is offline   Reply With Quote
Old 05-15-2017, 10:49 AM   #3
697498chevy
My 1969 C 10 has the original air cleaner . Don't know how to post pics, tho . Let me know if I can help .
697498chevy is offline   Reply With Quote
Old 05-15-2017, 03:39 PM   #4
dtkarst
I don't want to go cutting and making new holes and making something fit while have a couple random open holes. If I'm going to do it, it's going to be done the way the factory had because I'm just a particular s.o.b. When it comes to original stuff. The rest of the pickup is all original from the factory so I'd like to have it stay that way. 697498Chevh if you could get a picture let me know
Old 05-15-2017, 03:45 PM   #5
697498chevy
Be glad to take a pic . Can I text it to you ?
Old 05-15-2017, 05:12 PM   #6
tommys72
tommys72's Avatar
Heres mine, 350 with 4 barrel and ac. I realize the 4 may be a different setup than the 2 barrel. But maybe it'll help you some
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 05-15-2017, 05:30 PM   #7
terry b
terry b's Avatar
Then buy the corect air cleaner.
Old 05-15-2017, 06:03 PM   #8
dtkarst
What do you think I'm trying to do. Knowing what a guy needs first might help don't ya think?
Old 05-15-2017, 06:13 PM   #9
dtkarst
Awesome pictures. Looks about the same as I need..could you possibly get a shot of the tube coming from the manifold. And on top of that manifold?
Old 05-15-2017, 07:03 PM   #10
Grumpy old man
Grumpy old man's Avatar
I've got the air cleaner /spacer/stove pipe you need pm me a # and I'll send you some pics
Grumpy old man is offline   Reply With Quote
Old 05-15-2017, 07:43 PM   #11
jjzepplin
jjzepplin's Avatar
I have an original I think but it has a spacer. No pipes go to it.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 05-15-2017, 08:03 PM   #12
tommys72
tommys72's Avatar
There ya go.
