Another Lowering Question
Hi All,
I am looking at this kit to lower my stock c20 - which combo should I go with if I want to go as low as possible without notching the frame and effecting the ride too much. I have not done the disc brake conversion which is why I havent gone the drop spindle route. Please post pics if you got'em! Thanks! |
![]() Join Date: Aug 2014
Re: Another Lowering Question
I like a 3/5" drop on most trucks. I believe a 3/5 would be about as low as most would want without having to notch IMO. Any lowering is going to affect ride some but most will like the ride equally as good if not better. Just make sure you get springs that work with your truck especially if you plan to tow any with it.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
#3 | |
Thanks! |
#5 | |
Moderator
![]() ![]() Join Date: Aug 2011
And are the rear pinion angle shims drop type? http://67-72chevytrucks.com/vboard/s...&postcount=222 Cause that's my plan 3" springs in front with my 2.5" spindles - 5" springs in rear with 2" drop angle wedges.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 05-24-2017 at 09:59 AM. |
#6 | |
Moderator
Same thing as a 2" drop block with the shim angle machined in, CPP makes them:
http://www.ebay.com/itm/261704855923...%3AMEBIDX%3AIT ![]()
Ah, those are cool! I have their standard blocks and added on shims.
You should be safe with a 3/5 drop. You could also probably get away with a 4 inch drop in the front. I think these truck look good with a little bit of a rake so I would go with a 4/4 or 4/5 drop. Other companies sell 4 inch front drop springs. I think. Before you spend your money on lowering the truck with coils it might be a good idea to save for the drop spindles. It is a better way of lowering and it will make your truck safer.
