Old 05-15-2017, 09:07 AM   #1
Mgicm
red hot rear wheel ..one side?
Very odd issue. Replaced master, brake booster, wheel cylinders on rear drums of a 73 3/4 ton GMC. When driving now several things happen. One is it feels like an egg you are rolling on. almost like a bent wheel or brake is grabbing. Front pads were redone and rotors machined. I cant tell if its front or rears that seem to be grabbing. So if I drive it about 10-20 miles, the rear right wheel gets red hot to the touch. rear left wheel is slightly warm. Smells like a burning smell from this one wheel a bit.
Adjusted rear brakes like 4x ..in..out...no change. rear drums are supposedly new.
I dont know where to go from here. Could it actually be something with the rear itself? An odd thing we noticed prior to adjustments - we pulled off rear wheels with truck jacked up in rear. put truck in drive. wheels spun..but right one stopped for no reason and then started again. left side wheel constantly spun. Never saw anything like it. Almost like something was telling it to stop.
Only other possibililty we thought of was the booster we put in was not an exact match of the original as far as the plunger. So it was modified a bit. Not sure if that could cause this.
sure appreciate any direction on this.
Mgicm is offline   Reply With Quote
Old 05-15-2017, 09:39 AM   #2
Jstock85
Re: red hot rear wheel ..one side?
You definitely have a brake shoe or drum grabbing and staying stuck. I wouldn't drive until you fixed that red hot side. Probably better be safe than sorry and replace the internals on that wheel..
Jstock85 is offline   Reply With Quote
Old 05-15-2017, 09:39 AM   #3
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
You didn't say anything about replacing the shoes. Are they new or did you reuse what was there? Brake shoes that have been soaked with brake fluid or gear oil will tend to grab and cause issues similar to what you are describing.
Mike
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 05-15-2017, 09:39 AM   #4
Jstock85
That may also expose your problem.
Old 05-15-2017, 09:50 AM   #5
Mgicm
HI
Sorry ..more info. Note that this work is being done by two shops now..not myself but Im trying to get into the wheels myself at times to see for myself.
We did replace the shoes on both sides. One odd thing noticed was that on the right (passenger) side, one shoe seemed much thinner than another. I didnt get a chance to check other side. I thought out of the box they were both same thickness?? Also changed on both sides was the wheel cylinder. Another issue there was that shop could not locate the proper angled wheel cylinder. Seems the one on the truck had the nipple for the brake line on an angle whereas the replacement came out straight. i believe the first shop had to bend the line. I had second shop check and sees no issues with the work done on the internals but obviously something is wrong.
At this point, im up for replacing anything but dont want to throw money away. What would be a good plan at this time...? to just redo all the parts on the red hot side like wheel cylinders, shoes, etc? What woudl make that right side stop and start for no good reason while on the jackstands? What causes a wheel to stick if it is not something with the rear itself and woudl tell the one brake to engage and disengage for no reason. Totally puzzled!
thanks!
Old 05-15-2017, 09:58 AM   #6
Jstock85
Yeah I would start from scratch if it were me.
Old 05-15-2017, 10:01 AM   #7
Mgicm
meaning to focus on that right side.. replace everything inside like shoes, wheel cylinder, etc?
Any chance the brake booster could be the cause as it was modified to make it work? I can say before any of this replacement work I never had any issues like this so something that was changed introduced this issue.
Old 05-15-2017, 10:54 AM   #8
Jstock85
It sounds like one of your replacement parts didn't fit. or the wrong part was packaged or maybe an error while installing. Once you start taking everything apart you should see obvious sign of wear and that'll show you what you need to do.
Old 05-15-2017, 11:09 AM   #9
geezer#99
geezer#99's Avatar
Check the 'runout' on your hub.
Could be a slightly bent axle or axle flange.
Old 05-15-2017, 11:25 AM   #10
Nick_R_23
Nick_R_23's Avatar
It sounds to me like you may have a plugged brake line on one side. When you hit the brakes, it'll force fluid through, but the blockage may be bad enough where it doesn't allow the pressure to release quickly, and keep the wheel cylinder engaged. A 1973 truck is probably due for new lines anyway.
Old 05-15-2017, 11:31 AM   #11
Jstock85
Good idea nick! Disconnect your lines at the prop valve and use compressed air. If thats all it is then you caught a break!!
Old 05-15-2017, 03:24 PM   #12
Dead Parrot
Focus on the right rear. The shoe is thinner because it is dragging all the time, causing the heat. Drag = wear = heat. The stopping while the wheels were off the ground was due to the drag.
It is possible to reverse the shoes on a drum brake system. Download a good picture of a Chevy drum setup and compare to yours.
A bad booster should affect all the brakes. A bad master cylinder should affect more then one wheel.
Suspect the prop valve, plugged line, bad wheel brake cylinder or incorrectly installed shoes and/or springs on right rear.
Dead Parrot is offline   Reply With Quote
Old 05-15-2017, 03:46 PM   #13
hewittca
hewittca's Avatar
I had a similar problem but not quite as severe. I thought, I'll do a full brake job and everything will be right again. I replaced drums, shoes, wheel cylinders, and all springs, but my left rear would not bleed properly. I decided it was time to do all new brake lines and now the brakes work perfectly.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 05-15-2017, 08:48 PM   #14
Honest Bob
Honest Bob's Avatar
I had a collapsed brake line lock up one of my front calipers, I imagine the same thing could happen in the rear.
Honest Bob is offline   Reply With Quote
Old 05-15-2017, 10:13 PM   #15
kwmech
The shop could have gotten the wheel bearings too tight also. AND if they got the angled wheel cylinders they may be the wrong inside diameter. You have 11'' or 13'' drums? They could have also reversed the shoes on 1 side, which would cause weird problems when engaging.
Old 05-15-2017, 11:37 PM   #16
asphaltburner
asphaltburner's Avatar
Old rubber flex lines can swell and obstruct brake fluid return. Pressure will build in the line, but not relieve. I have had to solve this problem before. It's a cheap fix.
Best of luck!
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 05-16-2017, 08:26 PM   #17
raceman6135
Dino burner
raceman6135's Avatar
I've had the parking brake (aka emergency brake) cable begin to seize on one rear wheel, which would then drag the shoes on that side, causing one hot drum/wheel and excessively worn shoes.
I agree with others who have said the issue could be anything at this point. Time for more investigation.
raceman6135 is offline   Reply With Quote
Old 05-16-2017, 09:50 PM   #18
RedBed
RedBed's Avatar
My front brakes did the same thing. Replaced the lines on both sides and was good as new.
1979 Chevrolet Bonanza/305/4L60/Edelbrock Performer/Holley 600 Classic
RedBed is offline   Reply With Quote
Old 05-17-2017, 05:25 PM   #19
truckin 79
All good advice here I would also throw in that maybe the wheel cylinders are the problem. I dont know why other shop could not locate the correct ones but there is a reason your truck had those wheel cylinders. I bet the new cylinders are pushing the shoes out to much where the old ones probably collapsed down further in the wheel cylinder. I would look up on online your self and try and find correct wheel cylinders for your truck. I recently replaced shoes, drums and wheel cylinders. The parts store only listed on set of WC but turns out there are 2 different ones for a 79 heavy half. Good Luck
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 05-18-2017, 07:08 AM   #20
riz
Inspect your brake lines.... if they are old or stretched they can actually collapse on themselves and cut off the flow of brake fluid...... ask me how I know.
RIZ
81 C10 short box
82 K5 Blazer
riz is offline   Reply With Quote
Old 05-18-2017, 09:14 AM   #21
Jstock85
Whats the verdict?? This issue ever get resolved?
