Old 05-15-2017, 10:43 AM   #1
Slik66
Slik66's Avatar
Factory bend in frame?
Can anyone tell me what the small UP bend in the frame on the passenger side around the fuel pump area is for?
I want to cut it out and straighten it and don't remember anything needing that extra clearance on my set up?
It's what you learn After you know it all that counts!
Slik66 is offline   Reply With Quote
Old 05-15-2017, 10:46 AM   #2
chevylookin
Re: Factory bend in frame?
My guess was always for the heavy duty extended oil filters.
chevylookin is offline   Reply With Quote
Old 05-15-2017, 12:07 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Yep, oil filters.
Old 05-15-2017, 12:15 PM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Oil filter clearance for I-6 engines.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-15-2017, 12:19 PM   #5
Slik66
Slik66's Avatar
Awesome! Thanks guys!
Old 02-01-2018, 06:43 PM   #6
66C10LB
Is this the factory bend that you are referring to? (it is located forward of the cross member on the passenger side) Mine has this bend, but the truck is equipped with a 283 V8 rather than an inline 6.
66C10LB is offline   Reply With Quote
Old 02-01-2018, 07:20 PM   #7
The Rocknrod
Moderator
That's it, they didn't make frames different for v-8 vs I6.
