Old 05-15-2017, 06:46 PM   #1
FAKKY
4l80e compatibility with 4.8/5.3
So ..... if you have a 4.8/5.3 engine from a truck/van that came OEM with a 4l60e ......
Couple it with a 4l80e from a different truck/van...
Does it all bolt right up - I read somewhere about having to get a custom convertor and/or spacer made with right bolt holes for flexplate ......but it didnt explain why. I know you need it if the engine is a "true" LS (LS1 example)
But unsure if not a true LS - like 4.8/5.3/6.0.
Also that the 4l60e and 4l80e same/different bolt pattern ?
etc
FAKKY is offline   Reply With Quote
Old 05-15-2017, 08:30 PM   #2
clinebarger
Re: 4l80e compatibility with 4.8/5.3
If you want to use the stock (70 Pound) 310mm 4L80E converter, You will need a Flexplate, Crank Spacer, Crank Bolts, & 6 Converter bolts from a '99-'07 2500/2500HD/3500 truck that has a 6.0L/4L80E combination.
A "LS" 300mm 4L60E converter has a extended pilot hub & uses a "Dished" Flexplate with a metric converter bolt circle.
ALL stock 4L80E converters have the same pilot hub spacing as earlier Hydramatic transmissions, Uses a Crank Spacer & a "Flat" Flexplate, 11.50" converter bolt circle (Same as TH400).
Here is a 2005 2500HD VIN if you want/need to buy parts from the dealer......
1GCHK23U15F912051
If you want a lighter....More performance oriented converter, "Most" custom Converter builders can build one with a Extended Hub style 4L60E Cover to fit your "Dished" Flexplate. Circle D, Yank, Vigilante/Precision are some builders that can do this.
clinebarger is offline   Reply With Quote
Old 05-15-2017, 08:43 PM   #3
FAKKY
Thank you !!!
---added
Old 05-15-2017, 09:45 PM   #4
FAKKY
Assume if you got a 4l80e with original 4l80e flexplate and spacer and bolts would be a direct swap (just remove the 4l60e flexplate)
How much do you like an aftermarket convertor over stock. Truck will be sub 300 HP for a while ....... so spending an extra $700 on a aftermarket convertor doesnt seem necessary. If you have to sepnd $50 on a new flexplate and $50 on spacers/bolts ...... if using donor flexplate/spacer is not an option ...... might be better just ponying up the $$ though.
Old 05-16-2017, 09:32 PM   #5
PunishedC10
That would be correct. Behind my 5.7 ls1 I used an sfi rated TCI flexplate and a Circle D stall convertor. The oem 4l80e torque convertor is heavy!!! But you can adapt it to the 4.8,5.3,5.7 ls motors
1964 Coupe Deville(cruiser)
1966 Chevy II Nova 2door Hardtop
1985 C10 LS1/4l80e, Ridetech coilovers,22”Coys
2019 F-250 Platinum-Deleted/Carli Supension 37” MT’s
2000 Trans Am WS6, LS1/T-56, too many mods to list
PunishedC10 is offline   Reply With Quote
Old 05-16-2017, 10:35 PM   #6
clinebarger
That is correct
How much do you like an aftermarket converter over stock. Truck will be sub 300 HP for a while ....... so spending an extra $700 on a aftermarket convertor doesnt seem necessary. If you have to sepnd $50 on a new flexplate and $50 on spacers/bolts ...... if using donor flexplate/spacer is not an option ...... might be better just ponying up the $$ though.
It depends on the Combination & Use of vehicle.
For a performance vehicle, A higher stall is necessary. With a low torque engine like a 5.3L.....The weight of a stock 4L80E converter, Real low stall speed, And the 2.48 1st gear ratio is going to be very detrimental to performance.....Especially out of the hole.
The internal transmission components that have to be accelerated up to speed in a 4L80E in first gear have a lot of heft!
The Overdrive Carrier & Hub , Forward Drum , These are directly driven by the Input Shaft.
The Direct Drum is spun in the opposite direction at 87% of engine speed.
This is easily 40# of weight that has to be accelerated from a dead stop, Then you have a 70# converter......
If your engine makes max torque at 2950, The best thing for performance & acceleration would be a 3000 rpm or a little higher stall converter in the smallest diameter possible.
Old 05-18-2017, 06:45 AM   #7
downeyballz
That's great info. My Silverado 6.0/4l80e can be kinda slow from a stop but its a lot of fun around town and I like the close gears better than my old denali (6.0/4l60e) plus I trust it more. But the truck defiantly uses more gas!
I did notice the stall speed on my 4l80e is around 2,300 rpm. supposedly higher than the 4l60e converter.
downeyballz is offline   Reply With Quote
Old 05-18-2017, 07:58 AM   #8
FAKKY
Thanks guys
Really wanting to do a 5.3/4l80e just to get on road with idea if I want pwoer later might add a turbo.
Looks like yard wants
$600 for 5.3
$400 for 4l60e
$800-$1000 for 4l80
I can get a new 4l80 for around $1500 out the door ..... stock convertor
will have to decide
Old 05-18-2017, 09:05 AM   #9
downeyballz
Look for a parts truck. I have bought a few and was able to sell the extra stuff to cover the purchase price. Vans came with a 4.8, 5.3 or 6.0 mated to a 4l80e. They also have an extra long harness.
Old 05-18-2017, 09:30 AM   #10
FAKKY
Yeah would love to but cant really fit in driveway and even if could wife/neighbours would be none to happy.
Having the truck Im working on under a cover is enough headache
Old 05-21-2017, 08:14 PM   #11
crazy longhorn
Fabricate till you "puke"
Understand, that your wife will eventually forgive you! "It is a bunch easier to beg for forgiveness, than it is to ask permission"! As far as the neighbors, they hear a bike or rod, & look out....oh he!!, its just Al playing Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
