drag it like you stole it
wiper switch connection
i have a new wiper switch from LMC. there are three prongs on it.
1 on one side and two close together on the other. i can get a pic if it is needed. i need to know what wire goes wire. btw, i have to run new wires. so there is no stock harness..
negative camber //LA\\ |
Does no harness mean that your motor is not wired either?
Anyway, I am not sure how much this will help but here goes. Looking at the switch with the two terminals that are close together on the left side as you look at it from the back. first terminal black wire or windshield washer pump if you have no wires second terminal dark blue wire or slow speed on your wiper motor third terminal light blue wire or fast speed on your wiper motor Jim |
thanks. which terminal is which on the motor? i wont be using the washer pump.
