Old 05-15-2017, 08:09 PM   #1
Ironhorse
Ironhorse's Avatar
4 Row Upper Rad. Brackets
Have (3) three complete sets of the upper radiator support brackets complete with good useable rubber cushions and nut plates for each set. Need to use your hardware/bolts. Needed if swapping from a 2 or 3 row radiator to the larger HD 4 row usually for the A/C trucks. Bead blasted, primed and painted semi-gloss black. Rubber cushions solid, no tears and very useable, some light pits on the brackets but still VERY solid and useable. $28 per set shipped, Priority Flat Rate box, money order only, do not have Paypal.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 05-17-2017, 08:14 PM   #2
jwn1975
Re: 4 Row Upper Rad. Brackets
I want a set. would you kindly measure the length of the bracket for me thanks
jwn1975 is offline   Reply With Quote
Old 05-17-2017, 09:32 PM   #3
Ironhorse
Ironhorse's Avatar
Have all three sets packed in my trailer, heading out to a two day swap meet in the morning. I can tell you the measurements though. The actual mount bracket measures 6 3/8'' from end to end. The saddle portion the rubber cushion slips into measures 4 1/4'', this is the section that lays against the radiator top section. As mentioned these are for the larger 4 row HD radiator that was usually in A/C equipped trucks. Let me know if you want a pair and I will set them back when I unload at the swap meet tomorrow. I will have limited inter-net connection but it may be later in the evening when I get to the motel. Thanks for the interest,
Wellington, Ks
Old 05-17-2017, 11:20 PM   #4
jwn1975
ill go up to the shop and measure my new radiator, I bought a 4 core.. Ill double check
Old 05-18-2017, 06:05 AM   #5
jwn1975
Ya those are what I need. I'll take a set. Pm me how you want paid please thanks!
Old 05-18-2017, 08:23 AM   #6
tjc
tjc's Avatar
I will take a pair also, pm your address Thanks
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
tjc is offline   Reply With Quote
Old 05-18-2017, 08:31 AM   #7
Ironhorse
Ironhorse's Avatar
TWO SETS SOLD one set to jwn1975 and one set to tjc
One set left
Thanks for the purchase, PMs sent to both with payment info.
Wellington, Ks
Old 05-18-2017, 02:13 PM   #8
chevycc1970
chevycc1970's Avatar
I'll take your last set. Can't have enough of these hanging in my shop.
chevycc1970 is offline   Reply With Quote
Old 05-18-2017, 07:07 PM   #9
Ironhorse
Ironhorse's Avatar
Thanks for the purchase, last set. Is SOLD to chevycc1970. PM to follow with payment info.
Wellington, Ks
