Old 05-16-2017, 01:03 AM   #1
WB72
Before and After
WB72's Avatar
Opinions on 67 vs.68 fenders.
Out of nessesity, a rotting cab, I am changing out my 72 cab with a 67 SBW cab. The PO of the cab, also had new in box front fenders as well as SWB bed sides for that year. So I purchased them as well as a bunch of other items. Anyway, I noticed that one front fender and one bed side are 67 (no signal light) and one 68 (with signal light). So, I plan to either graft in a patch panel or a signal light.
I ask of you, in your opinion, should I fill the holes, or graft in signals?
Plans are to have it slammed on air ride if that makes a differance.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 05-16-2017, 01:19 AM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Opinions on 67 vs.68 fenders.
I think '67s have a coolness factor all their own, so since you're halfway there already, I'd cover over the marker holes on the two fenders that are later than '67.
That depends on Canadian safety laws, however. If that's legal, I mean.
Does the cab have a small rear window? If so then 1967 all the way.
'68s have reflector-only markers, later years had lights, and even later, turn signals in front.
Old 05-16-2017, 06:51 AM   #3
OARNGESI
OARNGESI's Avatar
Fill them especially on a small window cab
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 05-16-2017, 07:37 AM   #4
Try to swap with someone to get the '67 parts. The bedside will be harder to find, so probably end up with filling that. I would make it appear '67 all the way with the small back window (I decoded your lingo I have never seen used before).
Old 05-16-2017, 08:33 AM   #5
hewittca
hewittca's Avatar
I agree with everyone above. If it's a small window '67 cab, then you definitely need to go with no marker lights. If it's a big window '67 then you can go either way, but I still think the no marker light look is better. Whichever way you go, I would also make sure the grill treatment is model year correct since '67 and '68 had slightly different trim/paint options.
One other thing. Are both of your bedsides from the same manufacturer? I think I read somewhere here on the board that the '67 bedsides and '68-'72 bedsides were not made the same. I think there is even one repro bedside that is missing a subtle detail, as in the small indentation around the wheel opening. I would check both sides to make sure they look the same.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 05-16-2017, 09:22 AM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
All SWB bedsides were made the same with the exception of the 67's with no side markers.
It was the LWB beds that were different. In 67, the LWB sides had the same "square" front fender opening while the 68-72 longbeds are "rounded". NO clue why GM did that.
All SWB bed and 1967 LWB, all surburbans and blazers (the patch is actually from a 1967 LWB, I cut a 72 bed down to a SWB and wanted it to look right):
1968-1972 LWB beds:
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 05-16-2017, 09:30 AM   #7
hewittca
hewittca's Avatar
That is true about the square vs. round corner (and I would also REALLY like to know why they did that), but I'm talking about the crease pointed out here that runs around the wheel opening. Some reproductions have this crease, some do not.
Old 05-16-2017, 09:34 AM   #8
67ChevyRedneck
Oh, I thought you meant the factory beds.
Yeah, I've seen some crappy versions of fenders where that reverse curve was terrible or almost non existent. I've bought quite a few patch panels that didn't have the reverse curve.
One of the big reasons I took on the task of cutting down a super nice longbed.
Jesse James
Project "On a Dime"
Old 05-16-2017, 03:29 PM   #9
'68OrangeSunshine
You may have to acquire a '67 hood and grille [and radiator support] to acheive the total 1967 look.
Old 05-17-2017, 12:22 AM   #10
WB72
Before and After
WB72's Avatar
Sounds like you have the same thoughts as i do. Fill panels are going to be installed.
I do have most of the bits and pieces that allow the conversion. I guess my next question would be should I register it as a 67 with the cab VIN or a 72 with the chassis VIN?
66,000 miles.
Alberta, CANADA
Old 05-17-2017, 12:24 AM   #11
WB72
Before and After
WB72's Avatar
The panels are all from the same manufacturer., well at least that's what the box says. I will check to see if they have the ridge. Do factory panels have the ridge?
66,000 miles.
Alberta, CANADA
Old 05-17-2017, 01:13 AM   #12
'68OrangeSunshine
Mostly a legal question. If the regulating agency looks for the frame VIN, although it's only a partial, there may be complications -- like needing titles to both frame and cab. If they only look at the VIN plate on the B pillar in the cab, it's a '67.
You need an expert on Canadian law, not a sea-lawyer from Tucson.
Old 05-17-2017, 08:20 AM   #13
hewittca
hewittca's Avatar
Yes they do. That's an original factory GM shortbed side in primer on my truck in that photo.
Old 05-17-2017, 05:03 PM   #14
Daves70
Daves70's Avatar
It really doesn't seem to be a big deal around here with classics. Every swap meet I go to , there is a guy selling ownerships (titles). He could re-register the truck as a 67 or use his vin tag and call it a 72 and no one will care. Legal not sure but he will not get bothered for sure. Cab swaps and frame swaps are common place anymore on both sides of the border now that these trucks are 50 years old.
Daves70 is offline   Reply With Quote
Old 05-18-2017, 12:40 AM   #15
WB72
Before and After
WB72's Avatar
I may casually ask a man in uniform when I get the chance.
I also have the original vin from the rusty old cab, I could replace the 67's with that. It would just be registered as a 72. Not many enthusiasts will ask to see my title to determine the year of the small back window.
66,000 miles.
Alberta, CANADA
Old 05-18-2017, 02:27 AM   #16
'68OrangeSunshine
In the US, it's illegal to swap the B pillar VIN plates. They check the special ''rose petal'' rivets.
Call it a '67 and call it good.
Old 05-18-2017, 02:03 PM   #17
cypressbog
Go Pack Go!
Cover the side marker holes and title it as a 67.
cypressbog is offline   Reply With Quote
Old 05-18-2017, 05:20 PM   #18
BILT4ME
Body shops are allowed to swap VIN plates and replace with "factory" rivets. In the event a cab is damaged in that area, they are allowed to remove and replace the VIN plate on the cab.
If it was me, I would find someone that has a body shop and discuss it with them and check your local laws. If you have the title to one truck or the other, then I would license it as the one with the title. However, if the frame and body VIN don;t match, it could be sticky.
I build a 69 Chevy K10 when I was in high school (a VERY long time ago) and it had a 1960 frame under it. I licensed it as a 69 because that's the truck I had a title to. The state I lived in at the time did not care what the frame numbers were. My truck had a 69 cab, 68 front end, 60 frame, 75 front axle, 70 engine, and a 79 rear axle. Johnny Cash Special.....
1970 GMC K2500
Dis-use is harder on a car than mis-use.
BILT4ME is offline   Reply With Quote
