Old 05-16-2017, 05:23 AM   #1
bighead
Control arm bushing question
In the process of replacing my upper and lower control arm bushings, 73/87 style, and have a question I need help with. After installing the bushing on one side of the arm, I slid the shaft into the bushing and it seems sloppy. Like at least 10-20 mils or more. Is the fit of the shaft to the inner sleeve supposed to be a press fit or tight fit or should it move around easily? Thanks!
bighead is offline   Reply With Quote
Old 05-16-2017, 07:04 AM   #2
PGSigns
PGSigns's Avatar
Re: Control arm bushing question
It will move some and will tighten up when you get it all pressed in and the ends pulled up tight.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
