Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 05-16-2017, 01:28 PM   #1
ct67_72
ct67_72's Avatar
Truck 12B Regear package. $229
Your choice of ratio, 12 bolt USA Standard ring and pinion set and master overhaul kit.
$229!
Dan.
Drivetrain parts and accessories.
68 medium green shortbed fleetside
ct67_72 is offline
Old 05-16-2017, 04:44 PM   #2
smitty62
smitty62's Avatar
Re: Truck 12B Regear package. $229
There is no way to put a 3:42 gear in a case that now has a 3:73 is there? I need a series 3 case, right? or is there a way around it? Thanks,
Smitty
Stepsides look like real trucks!
Smitty
smitty62 is offline
Old 05-16-2017, 04:52 PM   #3
ct67_72
ct67_72's Avatar
Smitty
Correct. You could go the other way, but not higher on a lower carrier.
Unless someone regeared to 3.73 and used thick gears. If its not the factory ratio check the stamping on the gear to see if they are on a 3.42 down carrier.
Dan.
ct67_72 is offline
Closed Thread
