![]() Join Date: Dec 2012
Rear axle centering to bed wheel well
Hey guys has anyone cut the front of the bed so the axle/wheel was centered in the bed wheel well?
I was told that with a load the axle moves back. But that means it is always off center like 95% of the time and fine when you have a load in bed or when towing. 5% or less. My truck will probably never have a load in it. So I was thinking of cutting a pie shape out of the front and moving the lip forward 1" If you have a link or a place where you have see it or done it please let me know. Thank you Scott
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
Re: Rear axle centering to bed wheel well
Leave it alone, don't let it bother you. These trucks are immaculate beings, hence the humongous following that continues to grow after all these years
Why not use an adjustable spring perch and move the axle into position?
Dan. Drivetrain parts and accessories. 68 medium green shortbed fleetside |
![]() Join Date: Feb 2014
Look at the "axle off set plates" offered by Off Road Design.com.
Posted via Mobile Device |
You're splitting hairs Scott! If its bothering you that much go the suspension route. You are probably a lot better than me but when i start "cutting" bad things happen...
Looks fine.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
I have already moved the axle backwards due to the shackle flip kit. It is at the correct location for stock. My question was has anyone cut the fender to make it even?
Thanks for the replies
I used to cut them to clear bigger tires than you have with less lift when I rode them hard and put them away wet years ago
Looks even!!! Lol. Big tires on that truck. Looks like a fun time.
Appreciate the comments. Looking to do a few things that are subtle but custom.
I cut a pie piece out of my Jimmy. It's about 6" long and 5/8" wide at the very bottom. This makes the wheel well almost perfectly round removing the "hook". I also re-drilled the perches on my 9.5" sf 14 bolt to move it back. I needed to move mine as much for the custom driveshaft I had made for the 12 bolt because the nose of the 14 was longer. But it is centered quite well and doesn't grab the lip on big bumps any more.
#11 | |
#12 | |
I've seen wheel openings "radiused" to look factory. I think shifting the axle is your best bet, w/o getting into complex body work
#13 | ||
"I ain't nobody, dork."
Without them being "offset"... to me they would look weird.
![]() Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#14 |
I'll see what I can do this weekend if the weather cooperates.
