05-18-2017, 11:24 AM | #1 |
anyone know where I can find a filler neck?
I have a 82 Chevrolet long bed step side and I can find a filler neck.
Anyone have 1 or know where I can get 1? I have tried Classic - LMC and the Filling station. Thanks in advance. |
05-18-2017, 11:35 AM | #2 |
Post Whore
Re: Ianyone know where I can find a filler neck?
Lmc has them..which part are you looking for?...http://www.lmctruck.com/icatalog/cc/full.aspx?Page=49
05-18-2017, 12:50 PM | #3 | |
05-18-2017, 01:53 PM | #4 |
Post Whore
Which piece are you needing..the metal piece or the rubber hose..
05-18-2017, 03:26 PM | #5 |
You may be able to modify the one for the longbed fleetside to fit yours. Or short step for that matter. Cool truck, by the way, you do not see too many long steps. Worst case scenario, there are plenty of fab shops, that make jobs like this child's play.
05-18-2017, 11:55 PM | #6 |
if LMC don't have it. try classic ind, brother, classic parts, then start hitting the junk yards
05-19-2017, 07:55 AM | #7 |
I don't think anyone sells them for stepsides. I searched all over for my truck. I used one from a fleetside coupled together with a generic fuel filler from O'Reilly's. I found a piece of metal conduit from Home Depot to put them together. Not an ideal solution, but it has worked fine for about 5 years now.
05-19-2017, 12:03 PM | #8 |
Watch out for your cornhole !
Re: anyone know where I can find a filler neck?
I also just assemble them however I can.
Summit Racing sells mandrel bends in all different sizes and Rockauto sells fuel filler hose in different sizes and with 45 and 90 degree bends if needed. This is a 74 model flange welded to an 87 model neck with an old elbow and a couple of pieces of new hose. I have done similar with stepsides (about to do it again real soon). Between various bends of steel tubing and various bends of rubber hose you can pretty much put anything together if you scratch your head enough and figure out a game plan. Fuel filler stuff seems to be about the weakest area of the aftermarket for support on guys trying to fix up old cars and trucks.
05-19-2017, 12:45 PM | #9 |
05-19-2017, 01:13 PM | #10 |
Now that is solid damn work you did there. Guys pay professional builders to do work that doesn't turn out that nice.
We do have to deduct style points for using hose clamps with long tails sticking out though. How do you sleep at night ?
05-19-2017, 01:33 PM | #11 |
I bought mine from here. One fit perfect. The otherside I had to cut and I used a fence post to splice it. had to cut it and twist it a couple degrees. Easy fix
http://gastankdepot.bmobilized.com/?...ler-necks.html Chris
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
05-19-2017, 02:17 PM | #12 | |
As for the hose clamp? I came down with a case of havetodriveititis! |
05-19-2017, 03:12 PM | #13 |
Thanks all. I am modifying one from a fleet side.
05-19-2017, 04:01 PM | #14 |
That's right, I remember now. You have to drive like two time zones over just to get to the store. I'll give you a hardship pass on it then.
05-21-2017, 06:41 PM | #15 |
No one reproduces the metal necks yet. I grab all of the stepside ones that I find. I am glad someone is finally making rubber hoses that will work for the earlier trucks though
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
05-22-2017, 09:28 AM | #16 |
Where did you get that short 90 degree rubber hose coming off the tank?
05-22-2017, 11:10 AM | #17 |
I picked it up at a local rubber supply store, it was a universal 90* hose that I cut down to just the elbow. I know they're listed on Oreillys site under Gates hoses, or you could probably just google "Gates 90* universal hose" in the size you need.
05-22-2017, 02:46 PM | #18 |
Ok thanks all for the info I finally got the neck figured out. Now to replace the wood. My bed has surface rust on the inside. Are the angle strips that run along the inside of the bed spot welded to the bed wall?
05-22-2017, 03:26 PM | #19 | |
Mar-K sells replacement angle strips and they sell angle strip covers that go on top of ugly angle strips if you don't want to mess with changing the strips themselves.
05-24-2017, 08:29 AM | #20 |
I guess I should have asked this before I ordered but... What am I getting into buying the wood bed flooring kit from LMC?
05-24-2017, 09:17 AM | #21 |
I would save my money, and get some treated wood from the harware store. And then dump some used motor oil on it to keep it from rotting. That is how my dad, and many other old men have done it.
05-24-2017, 09:27 AM | #22 |
well too late now. Does anyone know of the quality of the kits?
05-24-2017, 11:08 AM | #23 |
05-25-2017, 10:54 AM | #24 |
Where do the bigger bolts go and the long ones?
05-27-2017, 10:20 PM | #25 |
A little late, but here's a 79-83 step side filler neck.
