Rebuilding 12 bolt
Just wondering if anyone has rebuilt there own 12 bolt and the difficulty involved. Is this something that can be done yourself to save money or does it have to be done by a shop?
Re: Rebuilding 12 bolt
Unless you have the tools to set clearances and pinion depth etc. and are used to working with setting tolerances I would not do it myself. However, if you do the grunt work and take the rear end to the shop so it's a bench job you could probably save some money.
what would be considered the grunt work?
#4 | |
rebuilding a differential properly takes specialty tools and experiance. If you are only changing bearings and seals its not quite as bad as replacing components like the gears or carrier. You sill still have ot be able to measure and adjust preload on the bearings and at minimum check the backlash and gear pattern. For the cost of a mistake, its generally less to have someone do it.
Dan. Drivetrain parts and accessories. 68 medium green shortbed fleetside |
I have a guy in Lake Forest that does them on the side. Something like that I want it done by a tech that does it all day.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Oh and there is someone offering a complete rear end rebuilt with new bearings, ring and pinion and brakes in OC CL for $900 exchange.
Some shops rebuild 'em in the truck and some would rather do them on the bench. The "grunt work" is removing, transporting and re-installing the rear end. Old U-bolts n' stuff put up a pretty good fight sometimes.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
