05-18-2017, 12:53 PM | #1 |
Fuel Line Bending Tip
After collapsing my share of metal tubing over the years I came up with a shade tree solution that worked for me. I had a length of braided accelerator cable left over from an earlier job. I inserted the cable into the full length of the fuel line that I was bending. The bends came out perfect and the cable was easy to pull out after all the bends were made.
I know there are other tricks out there for bending fuel/brake lines, but I really like this one. POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
05-18-2017, 01:07 PM | #2 |
One of the First
Re: Fuel Line Bending Tip
Smart!
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
05-18-2017, 02:10 PM | #3 |
or you could use a tool that bends tubing
05-18-2017, 02:22 PM | #4 |
Nice, follows the same principle of mandrel bending. I was borne on a farm, and it serves the necessity of the mother!
05-18-2017, 02:39 PM | #5 |
Moderator
Pretty slick
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-18-2017, 02:47 PM | #6 |
Great idea and easier and less messy than filling line with sand.
05-18-2017, 03:05 PM | #7 |
'71 C/20 350/T350. |
05-18-2017, 04:24 PM | #8 |
05-18-2017, 06:58 PM | #9 | |
POP
05-18-2017, 10:22 PM | #10 |
Who Changed This?
That must be a better version than the one I bought at O'Reallys. Mine is a real POS that will kink a line in a heartbeat, unless you fiddle with it a lot. I've had better luck using a couple of box end wrenches.
05-18-2017, 10:29 PM | #11 |
I have the same tool (linked by a member here) and after a certain angle, all bends are kinked. The accelerator cable idea is one I may copy, thanks!
05-18-2017, 11:23 PM | #12 |
I've bent tube by filling with water, freeze it and bend it.
05-18-2017, 11:33 PM | #13 | ||
"I ain't nobody, dork."
I have a tubing bender made by Mac Tools. It is made out of a pretty tuff nylon material. Makes great bends with no kinks at all. Here is a 3/8" fuel line I bent up and had one bend well past 90 degrees.
Kind of a bad pic of the bender, but it's the only one I have on file here. Fuel line. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
05-19-2017, 12:47 PM | #14 |
Good simple solution.
Couple of mine are using Ni-Copp line that is extremely easy to bend. And when working with steel, use of a torch to anneal the line to eliminate work hardening from the production process. Makes bending & flaring much easier. Not good for coated lines of course.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
05-19-2017, 02:09 PM | #15 |
67-72 parts collector,…
This is a great tip for someone with out a bender.
But bending tube is only as good as the bender you use. Buy the best bender that you can afford. (and flaring tool also)
