Old 05-18-2017, 09:23 PM   #1
dme922
dme922's Avatar
5.3 falling on its face
I am having an issue with my 5.3 falling on its face at a hard take off. It smells like it is running rich when i let it idle in the garage and rev it up. Need some ideas on what to check. It is dbw with a return style fuel set up and a th350 behind it.
dme922 is offline   Reply With Quote
Old 05-18-2017, 09:53 PM   #2
Lower
Lower's Avatar
Re: 5.3 falling on its face
Are you running the o2 sensors?
~Jon
Ol Green 1970 K10ish LWB,454/400/205, been in family since new.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=516056
Lower is offline   Reply With Quote
Old 05-18-2017, 09:54 PM   #3
dme922
dme922's Avatar
Yes. They are in my header collectors
Old 05-18-2017, 10:51 PM   #4
cdog73
hope you get some info, cause I just completed my install a few weeks ago and now my truck is doing the same exact thing. I have a Boyd Welding fuel tank with an in tank pump, and I feel its either a air or fuel issue. it ran fine for about two weeks and now this issue just popped up. Stopped at the parts store and it isn't throwing any codes. I'm stumped.
cdog73 is offline   Reply With Quote
Old 05-18-2017, 11:34 PM   #5
sprint_9
sprint_9's Avatar
What has been done on the tune?
sprint_9 is offline   Reply With Quote
Old 05-18-2017, 11:36 PM   #6
dme922
dme922's Avatar
I got my ecm from a board member and as far as i know he just deleted the stuff i didnt need.
Old 05-18-2017, 11:41 PM   #7
ls1nova71
ls1nova71's Avatar
What's your fuel pressure?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-18-2017, 11:44 PM   #8
dme922
dme922's Avatar
I am going to check that this weekend when im off work. I was just looking for some ideas.
Old 05-19-2017, 10:57 AM   #9
Custom 68
Custom 68's Avatar
Make sure all your fuses are good and the fuel pressure check out as well. Then you will need to talk to the tuner or decide on getting it tuned. With the TH350 it may be looking for some info (speed and such) from the trans it is not getting. I have not studied swapping for an old style trans. I know it can be done but I am not sure on tuning it. Maybe nothing? I have ran a 4l60, t56 and currently a 4l80 but those all have provisions for the computer.
Are you running exhaust?
Do you have a check engine light if so is it on?
good luck
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 05-19-2017, 11:47 AM   #10
Hart_Rod
Hart_Rod's Avatar
Make sure your O2s are plugged into the correct side.
Hart_Rod is offline   Reply With Quote
Old 05-22-2017, 09:58 AM   #11
dme922
dme922's Avatar
Thanks. Ill check that out. One thing i did find out this weekend is that my ecm is losing communication for some reason.
Old 05-22-2017, 11:13 AM   #12
Hart_Rod
Hart_Rod's Avatar
Do you have your exhaust system installed?
Old 05-22-2017, 11:21 AM   #13
dme922
dme922's Avatar
Yes
Old 05-22-2017, 12:44 PM   #14
Hart_Rod
Hart_Rod's Avatar
ECM is losing connection with what? DBW pedal?
Old 05-22-2017, 12:59 PM   #15
dme922
dme922's Avatar
We were trying to see what was going on with my fan trigger wires and when the temp reached 205 ( thats where the guy i got my ecm set it was set to come on) is when it said lost communication.
Old 05-22-2017, 02:29 PM   #16
akdg87
akdg87's Avatar
i was running a th350 with my 5.3 and every time it lost the speed sensor signal it fell on its face; it would retard the ignition (verified with hp tuners scanner) and run like complete crap.
There are some settings you can change in the tune but i could never figure out which one. I eventually swapped to a 4l80, but still have the dakota digital sensor laying around if you need one..
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 05-22-2017, 08:01 PM   #17
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I want to be clear on this issue. Is the ECM triggering a code/error saying it lost connection (like one of the U-codes)?
Or is it actually disconnecting if your watching a data log/live feed?
Any updates on your other troubleshooting?
(btw smelling rich at idle is normal for these if its a stock tune with bolt-on's, the stock tunes are fat for safety from the factory, and depending on the setup the ecm might even be running it even fatter, depending what the ECM is seeing for air flow.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-22-2017, 08:35 PM   #18
dme922
dme922's Avatar
He had it hooked up to a tech 2 computer and when it reached the set temp for the fans is when he said it lost communication. I did not see what his computer said.
Old 05-23-2017, 11:08 PM   #19
Robznob11
Robznob11's Avatar
Be sure to check the fuel psi under load! Also if your mass air meter is not plumbed correct it can do that. Some people put it close to the tb and it will jack up the readings causing all sorts of mess.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 05-24-2017, 08:45 AM   #20
dme922
dme922's Avatar
I checked the fuel pressure and it checked out good under a load. My maf sensor is mounted close to the tb due to the engine cover im using so i will put the regular cold air intake on and see what happens. Thanks
