05-18-2017, 09:26 PM | #1 |
does A/C need a relay? ignition switch HOT to touch
When i run my A/C (classic Air) the terminal on back of my Ignition switch get very hot to touch.
I notice my a/c switch get power from what appears to be a heavy gauge wire from the fuse box. Do A/C units need a separate Relay kit? thanks Allan |
05-18-2017, 09:45 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: does A/C need a relay? ignition switch HOT to touch
Most aftermarket ac systems do have a relay. I have an Old Aitlr Products system and it has one. I also do everything I can to avoid pumping modern accessories through my trucks switches or fuse block. Headlights are an example.
Good luck!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-19-2017, 10:12 AM | #3 |
thanks i will see about getting a relay
05-20-2017, 09:06 AM | #4 |
I added a painless relay kit to my radiator coolant fan, this seems to have fixed my problem.
Will keep an eye on it, may add a A/C blower relay kit later, i think i can use the same painless coolant fan kit |
05-22-2017, 10:11 PM | #5 |
added the relay for my A/C today , ignition switch now cool to touch. i think this is going to take care of the problem.
05-22-2017, 10:18 PM | #6 |
Outstanding!
05-30-2017, 10:14 AM | #7 |
added thermostat switch to radiator fan, love this , much better than 100% on
05-31-2017, 10:47 PM | #8 |
IMO, we guys would be smart to keep a 'few' relays lying around. Standard in their build and wiring, buying a few at one time is a cheap investment, and before you know it, you are out of them and need to order more. I like to get caught up into sensible habits that we don't ever have to 'break'.
sam |
06-01-2017, 09:00 AM | #9 |
Moderator
Hasnt been a good match with my car/truck hobby.
