05-18-2017, 10:39 PM | #1 |
Headlamp wiring 1958
Hey guys I'm wiring my headlamps and this may be a stupid question but can you tell me which terminal goes to which light, low beam and high-beam? One of the terminals has three live wires and the other one only has two. Sorry if this is a stupid question thank you very much in advance
05-18-2017, 10:43 PM | #2 |
Re: Headlamp wiring 1958
Also each of the 4 headlamp buckets is stamped r1, r2, L1, L2. I assume R1 is passenger side low beam. Please confirm if I'm correct. Thanks!
05-18-2017, 11:20 PM | #3 |
Pics
05-19-2017, 11:05 AM | #4 |
the socket with 2 green wires has hi/lo and the other only has lo
the hi/lo goes on the outside light make sure the lug is grounded well to prevent problems down the road
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-19-2017, 04:06 PM | #5 |
Hollister Road Co.
Your missing a wire. you need a Hi wire (green). Low wire (tan)and a ground wire (black)
05-20-2017, 11:08 AM | #6 |
post a pic of the back of the plugs
only 2 wires out of the bucket to the plug on the inner fender, the black wire out of the bucket is his lo beam must be 2 black wires to separate terminals in the first plug: hi and ground
05-20-2017, 03:22 PM | #7 |
This shows the 4 light system with relays hooked up but has a clear diagram of the actual headlight wiring from the relays to the lights.
If you aren't running relays just follow the path of the wire colors and you should be good. the diagram was borrowed from here http://www.rowand.net/Shop/Tech/imag...ingDiagram.jpg
