Old 05-19-2017, 09:59 AM   #1
AnobleL74
water leak in cab, under carpet ?
i notice water under my carpet after i go thru car wash, it shows up at bottom of kick panels and under center of floor pans.
there are no water leaks in the car systems.
is it possible the water is coming in thru the cowl vents then down the firewall/kickpanels and under carpet.?
are there seals /drains under vent cowl i can check/repair?
thanks
Allan
AnobleL74 is offline   Reply With Quote
Old 05-19-2017, 10:05 AM   #2
PGSigns
PGSigns's Avatar
Re: water leak in cab, under carpet ?
Where under the carpet? Many car washes now have the sprayers the do the bottom of the vehicle. That will allow it to come in in a few places like the clutch pedal pass through and any other place that is low in the floors.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-19-2017, 10:09 AM   #3
AnobleL74
Jimmy
center of each floor pan and corners where floor meets kick panel
i will look for holes under as you mentioned also
thanks
Old 05-19-2017, 10:11 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Here is a thread on the kick panel vent repair: http://67-72chevytrucks.com/vboard/s...d.php?t=434587
There are drains between the cab and the fender for the kick panel vent. They do get clogged. http://67-72chevytrucks.com/vboard/s...d.php?t=687764
There are sometimes also holes in the floor. http://67-72chevytrucks.com/vboard/s...d.php?t=437306
Old 05-19-2017, 01:12 PM   #5
65 C20
I had leaks like you mentioned and what I found was that on the inside of the fender well where the side kick panel meets the floor board that it is spot welded and also has seam sealer on the joint. Over the years the seam sealer had dried out and some of it had fallen out. When I washed the truck the water would go behind the cowl extension and leak down to the seam and leak on the inside.
I managed to get it chaulked up with out removing the wheel but would have been easier with the wheel off.
65 C20 is offline   Reply With Quote
Old 05-19-2017, 03:20 PM   #6
rvrfoot
Mine did the same thing. I replaced my vent seals and it fit it.
rvrfoot is offline   Reply With Quote
Old 05-20-2017, 12:20 AM   #7
Captainfab
60-66 Nut
In my experience a wet floor is usually a result of a leak around the windshield.
Old 05-20-2017, 08:36 AM   #8
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
This is where my leak was :
http://67-72chevytrucks.com/vboard/s...23#post6038323
66 C20 Service Truck:
Old 05-20-2017, 09:09 AM   #9
AnobleL74
thanks of all the good tips, my kick panels are carpet covered and the vent door assemblies are not there, will remove carpet and seal up the vent openings, see if that helps.i don't need the vents since i have A/C.
Old 05-20-2017, 10:39 PM   #10
franken
Water in the cab is sometimes from the roof gutters. See if the seam sealer has gone south.
franken is offline   Reply With Quote
Old 05-21-2017, 08:11 AM   #11
The Rocknrod
Moderator
Also check the firewall where it meets the cab at the top of the firewall, you have to stick your head under the base of the hood, could be rusted and have holes.
Old 05-21-2017, 10:21 AM   #12
AnobleL74
good ideas, already sealed the roof gutters, they were bad, will now check the firewall area.
thanks
Old 05-21-2017, 10:42 AM   #13
rvrfoot
What did you use for the drip rails?
Old 05-21-2017, 11:12 AM   #14
AnobleL74
mine were in decent shape , some cracking along putty seams, so i just cleaned and rough sanded, then put 2 heavy coats of rustoleum. got a pretty decent paint color match since my truck is patina paint so it worked for me.
Old 05-21-2017, 10:32 PM   #15
65chevysub
65chevysub's Avatar
I had the same problem with my 65 Suburban. Drove me crazy trying to figure out where the water was coming from. Finally figured out it was the cowl vents inside. I used a "putty tape" and havent had a leak from them since but lost all my carpet because of the water.
65chevysub is offline   Reply With Quote
Old 05-22-2017, 01:41 PM   #16
par4tom
This is definitely a cowl vent issue. The water is coming in from the air inlet in front of the windshield, then pouring down the inside of these vents. The factory vent has a lip on it to keep the water out.
I modified my vents and first time I washed it...water was puddled up on the floor. Once I sealed these off, never had another drop of water in the cab.
Tom
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 05-22-2017, 03:15 PM   #17
phraza
phraza's Avatar
Mines got a similar leak but not as bad. Only in heavy rain, there is a slight trickle down the middle of the cab behind the dash. Will investigate the cowl area!
Love this forum haha
Cheers
Fraser - New Zealand
1964 Chevy C10 Stepside
350 V8
Build thread here
phraza is offline   Reply With Quote
Old 05-22-2017, 04:07 PM   #18
rvrfoot
I took my heater box out and installed a block off plate. I did not put anything on it like weather striping. Mine is leaking from there.
Old 05-30-2017, 10:16 AM   #19
AnobleL74
my truck has no vents installed, just open holes
any ideas how i can cover and see them off?
vents not used/needed as they are carpet covered and i have A/C
Allan
Old 06-07-2017, 03:33 PM   #20
AnobleL74
I covered and sealed them still have leak , not coming from there so will try cowl top side area
